nav2_map_server.launch.py:
import os
map_file = os.path.join(get_package_share_directory('map_server'), 'config', 'turtlebot_area.yaml')
return LaunchDescription([
Node(
package='nav2_map_server',
executable='map_server',
name='map_server',
output='screen',
{'yaml_filename':map_file}
Node(
name='lifecycle_manager_mapper',
output='screen',
{'autostart': True},
{'node_names': ['map_server']}])
setup.py:
import os
from glob import glob
from setuptools import find_packages, setup
package_name = ‘map_server’
setup(
name=package_name,
version=‘0.0.0’,
packages=find_packages(exclude=[‘test’]),
data_files=[
(‘share/ament_index/resource_index/packages’,
[‘resource/’ + package_name]),
(‘share/’ + package_name, [‘package.xml’]),
(os.path.join(‘share’, package_name, ‘launch’), glob(‘launch/.launch.py’)),
(os.path.join(‘share’, package_name, ‘config’), glob('config/’))
install_requires=[‘setuptools’],
zip_safe=True,
maintainer=‘user’,
maintainer_email=‘user@todo.todo’,
description=‘TODO: Package description’,
license=‘TODO: License declaration’,
tests_require=[‘pytest’],
entry_points={
‘console_scripts’: [
package.xml:
<?xml version="1.0"?>
map_server
0.0.0
user
rclpy
<test_depend>ament_copyright</test_depend>
<test_depend>ament_flake8</test_depend>
<test_depend>ament_pep257</test_depend>
<test_depend>python3-pytest</test_depend>
ament_python
