So I am trying to put my path_planner_server and localization files together into a single launch file to move my robot but its not working. I keep getting 3 errors(The main error is in white and not displaying red). My code is copied and pasted from the solution and its still not working as expected. If I run my localization file, then my path_planner_server file, it works great and the robot moves. But once I try to put them together it stops working even though I copied and pasted the solution to verify it would work but it didn't. chatGPT suggested it could be the controller.yaml file but I haven't changed it. Help would be great :)
