What is this error? Simply, I did the proposed commands (copy - paste). What must I do for correct this?
Hello there,
i think it’s about indentation error, it means that you have an indentation where it should not be.
Ps : indentation is that space at the beginning of the line, you only add when inside new block of code.
hope it helps ![]()
