[Bug] Wrong shell number referenced
In the exercise the last point is to verify the file `*.txt` was copied to docker, and it said "Execute in Shell #2 ls -lh /root" but it should be "Execute in Shell #1" because the shell 1 is where is the docker running
Thank you for reporting this. We’ll take a look and correct as necessary.
