i am new to ROS currently working on ROS Kinetic,i have an issue when i run this linefollowing.cpp file using the command “rosrun roscv linefollowing.cpp” (where roscv is the package name & “linefollowing.cpp” is the .cpp file),
the error;
/home/badhrisrini/line_follow_ws/src/roscv/src/linefollow.cpp: line 19: using: command not found
/home/badhrisrini/line_follow_ws/src/roscv/src/linefollow.cpp: line 20: using: command not found
/home/badhrisrini/line_follow_ws/src/roscv/src/linefollow.cpp: line 21: namespace: command not found
/home/badhrisrini/line_follow_ws/src/roscv/src/linefollow.cpp: line 22: static: command not found
/home/badhrisrini/line_follow_ws/src/roscv/src/linefollow.cpp: line 24: float: command not found
/home/badhrisrini/line_follow_ws/src/roscv/src/linefollow.cpp: line 25: float: command not found
/home/badhrisrini/line_follow_ws/src/roscv/src/linefollow.cpp: line 26: float: command not found
/home/badhrisrini/line_follow_ws/src/roscv/src/linefollow.cpp: line 28: class: command not found
/home/badhrisrini/line_follow_ws/src/roscv/src/linefollow.cpp: line 36: syntax error near unexpected token `('
/home/badhrisrini/line_follow_ws/src/roscv/src/linefollow.cpp: line 36: ` image_transport::Publisher image_pub_; //image publisher(we subscribe to ardrone image_raw)'
the code in this file is;
#include <ros/ros.h>
#include <stdio.h>
#include <iostream>
#include "std_msgs/String.h"
#include <image_transport/image_transport.h>
#include <cv_bridge/cv_bridge.h>
#include <sensor_msgs/image_encodings.h>
#include <opencv2/imgproc/imgproc.hpp> //make sure to include the relevant headerfiles
#include <opencv2/highgui/highgui.hpp>
#include <opencv/cv.h>
#include <opencv/highgui.h>
#include <cv_bridge/CvBridge.h>
#include <cvaux.h>
#include<math.h>
#include <cxcore.h>
#include "turtlesim/Velocity.h"
/*here is a simple program which demonstrates the use of ros and opencv to do image manipulations on video streams given out as image topics from the monocular vision
of robots,here the device used is a ardrone(quad-rotor).*/
using namespace std;
using namespace cv;
namespace enc = sensor_msgs::image_encodings;
static const char WINDOW[] = "Image window";
float prevVelocity_angular ,prevVelocity_linear ,newVelocity_angular ,newVelocity_linear ;
float derive_angular, derive_linear, dt = 0.5;
float horizontalcount;
class ImageConverter
ros::NodeHandle nh_;
ros::NodeHandle n;
ros::Publisher pub ;
ros::Publisher tog;
image_transport::ImageTransport it_;
image_transport::Subscriber image_sub_; //image subscriber
std_msgs::String msg;
public:
ImageConverter()
: it_(nh_)
pub= n.advertise<turtlesim::Velocity>("/drocanny/vanishing_points", 500);//
image_sub_ = it_.subscribe("/ardrone/image_raw", 1, &ImageConverter::imageCb, this);
image_pub_= it_.advertise("/arcv/Image",1);
~ImageConverter()
cv::destroyWindow(WINDOW);
void imageCb(const sensor_msgs::ImageConstPtr& msg)
sensor_msgs::CvBridge bridge;//we need this object bridge for facilitating conversion from ros-img to opencv
IplImage* img = bridge.imgMsgToCv(msg,"rgb8"); //image being converted from ros to opencv using cvbridge
turtlesim::Velocity velMsg;
CvMemStorage* storage = cvCreateMemStorage(0);
CvSeq* lines = 0;
int i,c,d;
float c1[50];
float m,angle;
float buf;
float m1;
float dis;
int k=0,k1=0;
int count=0;
float xv;
float yv;
int vc=0;
float xvan=0,yvan=0;
static float xvan1=0,yvan1=0;
float num=0;
static float count1=0;
float dv;
float vxx,vyy;
cvSetImageROI(img, cvRect(0, 0,170, 140));
IplImage* out1 = cvCreateImage( cvGetSize(img), IPL_DEPTH_8U, 3 ); //make sure to feed the image(img) data to the parameters necessary for canny edge output
IplImage* gray_out = cvCreateImage( cvGetSize(img), IPL_DEPTH_8U, 1 );
IplImage* canny_out = cvCreateImage( cvGetSize(img), IPL_DEPTH_8U, 1 );
IplImage* gray_out1=cvCreateImage( cvGetSize(img), IPL_DEPTH_8U, 3 );
IplImage* canny_out1 = cvCreateImage( cvGetSize(img), IPL_DEPTH_8U, 1 );
IplImage* canny_out2 = cvCreateImage( cvGetSize(img), IPL_DEPTH_8U, 1 );
cvSmooth( img, out1, CV_GAUSSIAN, 11, 11 );
cvCvtColor(out1 , gray_out, CV_RGB2GRAY);
cvCanny( gray_out, canny_out, 50, 125, 3 );
cvCvtColor(canny_out ,gray_out1, CV_GRAY2BGR);
lines = cvHoughLines2( canny_out, storage, CV_HOUGH_PROBABILISTIC, 1, CV_PI/180, 80,50, 10 );
for( i = 0; i < lines->total; i++ )
CvPoint* line = (CvPoint*)cvGetSeqElem(lines,i);
cvLine( out1, line[0], line[1], CV_RGB(0,255,0), 1, 8 );
cvLine( gray_out1, line[0], line[1], CV_RGB(0,255,0), 2, 8 );
xv=line[0].x-line[1].x;
yv=line[0].y-line[1].y;
velMsg.linear = atan2(xv,yv)*180 /3.14159265;
angle=velMsg.linear;
if(velMsg.linear<-90)
velMsg.linear=velMsg.linear+180;
buf=(line[0].x+line[1].x)/2;
if(abs(85-buf)<=15)
velMsg.angular =0;
else
velMsg.angular =(85-(line[0].x+line[1].x)/2);
if(abs(velMsg.angular)>50)
velMsg.angular =0;
printf("\nX::Y::X1::Y1::%d:%d:%d:%d",line[0].x,line[0].y,line[1].x,line[1].y);
pub.publish(velMsg);
cvSeqRemove(lines,i);
cvShowImage( "OUT1", out1 );//lines projected onto the real picture
cvShowImage( "GRAY_OUT1", gray_out1 );
cv::waitKey(3);
sensor_msgs::ImagePtr out = sensor_msgs::CvBridge::cvToImgMsg(img, "rgb8");//image converted from opencv to ros for publishing
image_pub_.publish(out);
cvClearMemStorage(storage);
cvReleaseMemStorage(&storage);
int main(int argc, char** argv)
ros::init(argc, argv, "image_converter");
ImageConverter ic;
ros::spin();
return 0;
CMakeLists.txt of the package “roscv” ;
project(roscv)
ardrone_autonomy
cv_bridge
image_transport
roscpp
sensor_msgs
std_msgs
std_srvs
turtlesim
find_package(OpenCV)
include_directories(
${catkin_INCLUDE_DIRS}
include_directories(${OpenCV_INCLUDE_DIRS})
catkin_package(
CATKIN_DEPENDS
ardrone_autonomy
cv_bridge
image_transport
roscpp
sensor_msgs
std_msgs
std_srvs
turtlesim
catkin_package(
INCLUDE_DIRS include
LIBRARIES roscv
CATKIN_DEPENDS ardrone_autonomy cv_bridge image_transport opencv2 roscpp sensor_msgs std_msgs std_srvs turtlesim
DEPENDS system_lib
add_executable(linefollowing src/linefollowing.cpp)
target_link_libraries(linefollowing ${catkin_LIBRARIES})
install(TARGETS linefollowing
ARCHIVE DESTINATION ${CATKIN_PACKAGE_LIB_DESTINATION}
LIBRARY DESTINATION ${CATKIN_PACKAGE_LIB_DESTINATION}
RUNTIME DESTINATION ${CATKIN_PACKAGE_BIN_DESTINATION}
i am aware that we cannot run a .cpp file in ros instead we have to run the ros executable file which will be build after building the package. but the issue is the after i run “cmake .” in the package directory and “catkin_make” in the workspace directory i can’t find the executable file which should have been created!
To be exact i am working on a line following drone using ARdrone 2.0 , openCV and a sliding mode controller. does Construct have any related course to this which can be helpful for this project (note: iam working on ubuntu 16.04(kinetic) and 18.04(melodic) versions not working in ROS Development studio). Any suggestions for the above issue and on my project?? thank you in advance!!
