can i see example_action_server.py file in web developement for robot course chapter 11 ?
Could you elaborate more? Do you mean an example of an action server in ROS or something related to web developement with an action server inside it using the javascript library of ROS?
If its simple an example of action server, in the Courses of ROS basisc in 5 days you can find some units that talk about action servers.
As for use in web developement , in the courses
https://app.theconstructsim.com/#/Course/42
https://app.theconstructsim.com/#/Course/44
Hope it helps
