Hi there, I wanted to know whether I can see the solution after submitting the quiz. I already got 10/10 but I still want to check the solution, but if I see the solution, will I be able to get the certificate or not. Thanks
You will get the certification if you have already submitted the test. The only thing to keep in mind is that if you ask for the solution then it’s not possible for you to write/rewrite that test, so make sure you complete the test and you are satisfied with your code.
