I followed the ros2 control course and tried to use the dynamixel hardware interface in my own labtop and this error was come. I’m not familiar with C++ so If someone know what should I fix, please tell me. Basically, I just copy and paste the code from the code to my pkg. I use ros2 foxy and DynamixelSDK and also workbench were also cloned from foxy-devel branch. In the terminal inside the Construct, nothing error.
In file included from /home/tharit/ros2_ws/src/dynamixel_hardware_interface/src/dynamixel_hardware_interface.cpp:7:
/home/tharit/ros2_ws/src/dynamixel_hardware_interface/include/dynamixel_hardware_interface/dynamixel_hardware_interface.hpp:44:3: error: ‘CallbackReturn’ does not name a type
44 | CallbackReturn on_init(const hardware_interface::HardwareInfo & info) override;
/home/tharit/ros2_ws/src/dynamixel_hardware_interface/include/dynamixel_hardware_interface/dynamixel_hardware_interface.hpp:50:3: error: ‘CallbackReturn’ does not name a type
50 | CallbackReturn on_activate(const rclcpp_lifecycle::State & previous_state) override;
/home/tharit/ros2_ws/src/dynamixel_hardware_interface/include/dynamixel_hardware_interface/dynamixel_hardware_interface.hpp:52:3: error: ‘CallbackReturn’ does not name a type
52 | CallbackReturn on_deactivate(const rclcpp_lifecycle::State & previous_state) override;
/home/tharit/ros2_ws/src/dynamixel_hardware_interface/src/dynamixel_hardware_interface.cpp:27:1: error: ‘CallbackReturn’ does not name a type
27 | CallbackReturn DynamixelHardware::on_init(const hardware_interface::HardwareInfo & info)
/home/tharit/ros2_ws/src/dynamixel_hardware_interface/src/dynamixel_hardware_interface.cpp: In member function ‘virtual std::vector<hardware_interface::StateInterface> dynamixel_hardware::DynamixelHardware::export_state_interfaces()’:
/home/tharit/ros2_ws/src/dynamixel_hardware_interface/src/dynamixel_hardware_interface.cpp:157:24: error: ‘info_’ was not declared in this scope
157 | for (uint i = 0; i < info_.joints.size(); i++) {
/home/tharit/ros2_ws/src/dynamixel_hardware_interface/src/dynamixel_hardware_interface.cpp: In member function ‘virtual std::vector<hardware_interface::CommandInterface> dynamixel_hardware::DynamixelHardware::export_command_interfaces()’:
/home/tharit/ros2_ws/src/dynamixel_hardware_interface/src/dynamixel_hardware_interface.cpp:173:24: error: ‘info_’ was not declared in this scope
173 | for (uint i = 0; i < info_.joints.size(); i++) {
/home/tharit/ros2_ws/src/dynamixel_hardware_interface/src/dynamixel_hardware_interface.cpp: At global scope:
/home/tharit/ros2_ws/src/dynamixel_hardware_interface/src/dynamixel_hardware_interface.cpp:183:1: error: ‘CallbackReturn’ does not name a type
183 | CallbackReturn DynamixelHardware::on_activate(const rclcpp_lifecycle::State & previous_state)
/home/tharit/ros2_ws/src/dynamixel_hardware_interface/src/dynamixel_hardware_interface.cpp:200:1: error: ‘CallbackReturn’ does not name a type
200 | CallbackReturn DynamixelHardware::on_deactivate(const rclcpp_lifecycle::State & previous_state)
/home/tharit/ros2_ws/src/dynamixel_hardware_interface/src/dynamixel_hardware_interface.cpp: In member function ‘virtual hardware_interface::return_type dynamixel_hardware::DynamixelHardware::read()’:
/home/tharit/ros2_ws/src/dynamixel_hardware_interface/src/dynamixel_hardware_interface.cpp:212:28: error: ‘info_’ was not declared in this scope
212 | std::vector<uint8_t> ids(info_.joints.size(), 0);
/home/tharit/ros2_ws/src/dynamixel_hardware_interface/src/dynamixel_hardware_interface.cpp: In member function ‘virtual hardware_interface::return_type dynamixel_hardware::DynamixelHardware::write()’:
/home/tharit/ros2_ws/src/dynamixel_hardware_interface/src/dynamixel_hardware_interface.cpp:265:28: error: ‘info_’ was not declared in this scope
265 | std::vector<uint8_t> ids(info_.joints.size(), 0);
/home/tharit/ros2_ws/src/dynamixel_hardware_interface/src/dynamixel_hardware_interface.cpp: In member function ‘hardware_interface::return_type dynamixel_hardware::DynamixelHardware::enable_torque(bool)’:
/home/tharit/ros2_ws/src/dynamixel_hardware_interface/src/dynamixel_hardware_interface.cpp:310:26: error: ‘info_’ was not declared in this scope
310 | for (uint i = 0; i < info_.joints.size(); ++i) {
/home/tharit/ros2_ws/src/dynamixel_hardware_interface/src/dynamixel_hardware_interface.cpp:319:26: error: ‘info_’ was not declared in this scope
319 | for (uint i = 0; i < info_.joints.size(); ++i) {
make[2]: *** [CMakeFiles/dynamixel_hardware_interface.dir/build.make:63: CMakeFiles/dynamixel_hardware_interface.dir/src/dynamixel_hardware_interface.cpp.o] Error 1
make[1]: *** [CMakeFiles/Makefile2:78: CMakeFiles/dynamixel_hardware_interface.dir/all] Error 2
make: *** [Makefile:141: all] Error 2
Failed <<< dynamixel_hardware_interface [1.83s, exited with code 2]
Summary: 12 packages finished [2.98s]
1 package failed: dynamixel_hardware_interface
1 package had stderr output: dynamixel_hardware_interface
Here is the .cpp code
#include <algorithm>
#include <array>
#include <string>
#include <limits>
#include <vector>
#include "dynamixel_hardware_interface/dynamixel_hardware_interface.hpp"
#include "hardware_interface/types/hardware_interface_return_values.hpp"
#include "hardware_interface/types/hardware_interface_type_values.hpp"
#include "rclcpp/rclcpp.hpp"
namespace dynamixel_hardware
constexpr const char * kDynamixelHardware = "DynamixelHardware";
constexpr uint8_t kGoalPositionIndex = 0;
constexpr uint8_t kGoalVelocityIndex = 1;
constexpr uint8_t kPresentPositionVelocityCurrentIndex = 0;
constexpr const char * kGoalPositionItem = "Goal_Position";
constexpr const char * kGoalVelocityItem = "Goal_Velocity";
constexpr const char * kMovingSpeedItem = "Moving_Speed";
constexpr const char * kPresentPositionItem = "Present_Position";
constexpr const char * kPresentVelocityItem = "Present_Velocity";
constexpr const char * kPresentSpeedItem = "Present_Speed";
constexpr const char * kPresentCurrentItem = "Present_Current";
constexpr const char * kPresentLoadItem = "Present_Load";
RCLCPP_DEBUG(rclcpp::get_logger(kDynamixelHardware), "configure");
if (hardware_interface::SystemInterface::on_init(info) != CallbackReturn::SUCCESS)
return CallbackReturn::ERROR;
joints_.resize(info_.joints.size(), Joint());
joint_ids_.resize(info_.joints.size(), 0);
joint_ids_[i] = std::stoi(info_.joints[i].parameters.at("id"));
joints_[i].state.position = std::numeric_limits<double>::quiet_NaN();
joints_[i].state.velocity = std::numeric_limits<double>::quiet_NaN();
joints_[i].state.effort = std::numeric_limits<double>::quiet_NaN();
joints_[i].command.position = std::numeric_limits<double>::quiet_NaN();
joints_[i].command.velocity = std::numeric_limits<double>::quiet_NaN();
joints_[i].command.effort = std::numeric_limits<double>::quiet_NaN();
RCLCPP_INFO(rclcpp::get_logger(kDynamixelHardware), "joint_id %d: %d", i, joint_ids_[i]);
if (
info_.hardware_parameters.find("use_dummy") != info_.hardware_parameters.end() &&
info_.hardware_parameters.at("use_dummy") == "true") {
use_dummy_ = true;
RCLCPP_INFO(rclcpp::get_logger(kDynamixelHardware), "dummy mode");
return CallbackReturn::SUCCESS;
auto usb_port = info_.hardware_parameters.at("usb_port");
auto baud_rate = std::stoi(info_.hardware_parameters.at("baud_rate"));
const char * log = nullptr;
RCLCPP_INFO(rclcpp::get_logger(kDynamixelHardware), "usb_port: %s", usb_port.c_str());
RCLCPP_INFO(rclcpp::get_logger(kDynamixelHardware), "baud_rate: %d", baud_rate);
if (!dynamixel_workbench_.init(usb_port.c_str(), baud_rate, &log)) {
RCLCPP_FATAL(rclcpp::get_logger(kDynamixelHardware), "%s", log);
uint16_t model_number = 0;
if (!dynamixel_workbench_.ping(joint_ids_[i], &model_number, &log)) {
enable_torque(false);
set_control_mode(ControlMode::Position, true);
enable_torque(true);
const ControlItem * goal_position =
dynamixel_workbench_.getItemInfo(joint_ids_[0], kGoalPositionItem);
if (goal_position == nullptr) {
const ControlItem * goal_velocity =
dynamixel_workbench_.getItemInfo(joint_ids_[0], kGoalVelocityItem);
if (goal_velocity == nullptr) {
goal_velocity = dynamixel_workbench_.getItemInfo(joint_ids_[0], kMovingSpeedItem);
const ControlItem * present_position =
dynamixel_workbench_.getItemInfo(joint_ids_[0], kPresentPositionItem);
if (present_position == nullptr) {
const ControlItem * present_velocity =
dynamixel_workbench_.getItemInfo(joint_ids_[0], kPresentVelocityItem);
if (present_velocity == nullptr) {
present_velocity = dynamixel_workbench_.getItemInfo(joint_ids_[0], kPresentSpeedItem);
const ControlItem * present_current =
dynamixel_workbench_.getItemInfo(joint_ids_[0], kPresentCurrentItem);
if (present_current == nullptr) {
present_current = dynamixel_workbench_.getItemInfo(joint_ids_[0], kPresentLoadItem);
control_items_[kGoalPositionItem] = goal_position;
control_items_[kGoalVelocityItem] = goal_velocity;
control_items_[kPresentPositionItem] = present_position;
control_items_[kPresentVelocityItem] = present_velocity;
control_items_[kPresentCurrentItem] = present_current;
if (!dynamixel_workbench_.addSyncWriteHandler(
control_items_[kGoalPositionItem]->address, control_items_[kGoalPositionItem]->data_length,
&log)) {
control_items_[kGoalVelocityItem]->address, control_items_[kGoalVelocityItem]->data_length,
&log)) {
uint16_t start_address = std::min(
control_items_[kPresentPositionItem]->address, control_items_[kPresentCurrentItem]->address);
uint16_t read_length = control_items_[kPresentPositionItem]->data_length +
control_items_[kPresentVelocityItem]->data_length +
control_items_[kPresentCurrentItem]->data_length + 2;
if (!dynamixel_workbench_.addSyncReadHandler(start_address, read_length, &log)) {
std::vector<hardware_interface::StateInterface> DynamixelHardware::export_state_interfaces()
RCLCPP_DEBUG(rclcpp::get_logger(kDynamixelHardware), "export_state_interfaces");
std::vector<hardware_interface::StateInterface> state_interfaces;
state_interfaces.emplace_back(hardware_interface::StateInterface(
info_.joints[i].name, hardware_interface::HW_IF_POSITION, &joints_[i].state.position));
info_.joints[i].name, hardware_interface::HW_IF_VELOCITY, &joints_[i].state.velocity));
info_.joints[i].name, hardware_interface::HW_IF_EFFORT, &joints_[i].state.effort));
return state_interfaces;
std::vector<hardware_interface::CommandInterface> DynamixelHardware::export_command_interfaces()
RCLCPP_DEBUG(rclcpp::get_logger(kDynamixelHardware), "export_command_interfaces");
std::vector<hardware_interface::CommandInterface> command_interfaces;
command_interfaces.emplace_back(hardware_interface::CommandInterface(
info_.joints[i].name, hardware_interface::HW_IF_POSITION, &joints_[i].command.position));
info_.joints[i].name, hardware_interface::HW_IF_VELOCITY, &joints_[i].command.velocity));
return command_interfaces;
RCLCPP_DEBUG(rclcpp::get_logger(kDynamixelHardware), "start");
for (uint i = 0; i < joints_.size(); i++) {
if (use_dummy_ && std::isnan(joints_[i].state.position)) {
joints_[i].state.position = 0.0;
joints_[i].state.velocity = 0.0;
joints_[i].state.effort = 0.0;
read();
reset_command();
write();
RCLCPP_DEBUG(rclcpp::get_logger(kDynamixelHardware), "stop");
return_type DynamixelHardware::read()
if (use_dummy_) {
return return_type::OK;
std::vector<int32_t> positions(info_.joints.size(), 0);
std::vector<int32_t> velocities(info_.joints.size(), 0);
std::vector<int32_t> currents(info_.joints.size(), 0);
std::copy(joint_ids_.begin(), joint_ids_.end(), ids.begin());
if (!dynamixel_workbench_.syncRead(
kPresentPositionVelocityCurrentIndex, ids.data(), ids.size(), &log)) {
RCLCPP_ERROR(rclcpp::get_logger(kDynamixelHardware), "%s", log);
if (!dynamixel_workbench_.getSyncReadData(
control_items_[kPresentCurrentItem]->address,
control_items_[kPresentCurrentItem]->data_length, currents.data(), &log)) {
control_items_[kPresentVelocityItem]->address,
control_items_[kPresentVelocityItem]->data_length, velocities.data(), &log)) {
control_items_[kPresentPositionItem]->data_length, positions.data(), &log)) {
for (uint i = 0; i < ids.size(); i++) {
joints_[i].state.position = dynamixel_workbench_.convertValue2Radian(ids[i], positions[i]);
joints_[i].state.velocity = dynamixel_workbench_.convertValue2Velocity(ids[i], velocities[i]);
joints_[i].state.effort = dynamixel_workbench_.convertValue2Current(currents[i]);
return_type DynamixelHardware::write()
if (use_dummy_) {
for (auto & joint : joints_) {
joint.state.position = joint.command.position;
std::vector<int32_t> commands(info_.joints.size(), 0);
if (std::any_of(
joints_.cbegin(), joints_.cend(), [](auto j) { return j.command.velocity != 0.0; })) {
// Velocity control
set_control_mode(ControlMode::Velocity);
commands[i] = dynamixel_workbench_.convertVelocity2Value(
ids[i], static_cast<float>(joints_[i].command.velocity));
if (!dynamixel_workbench_.syncWrite(
kGoalVelocityIndex, ids.data(), ids.size(), commands.data(), 1, &log)) {
} else if (std::any_of(
joints_.cbegin(), joints_.cend(), [](auto j) { return j.command.effort != 0.0; })) {
// Effort control
RCLCPP_ERROR(rclcpp::get_logger(kDynamixelHardware), "Effort control is not implemented");
return return_type::ERROR;
// Position control
set_control_mode(ControlMode::Position);
commands[i] = dynamixel_workbench_.convertRadian2Value(
ids[i], static_cast<float>(joints_[i].command.position));
kGoalPositionIndex, ids.data(), ids.size(), commands.data(), 1, &log)) {
return_type DynamixelHardware::enable_torque(const bool enabled)
if (enabled && !torque_enabled_) {
if (!dynamixel_workbench_.torqueOn(joint_ids_[i], &log)) {
reset_command();
RCLCPP_INFO(rclcpp::get_logger(kDynamixelHardware), "Torque enabled");
} else if (!enabled && torque_enabled_) {
if (!dynamixel_workbench_.torqueOff(joint_ids_[i], &log)) {
RCLCPP_INFO(rclcpp::get_logger(kDynamixelHardware), "Torque disabled");
torque_enabled_ = enabled;
return_type DynamixelHardware::set_control_mode(const ControlMode & mode, const bool force_set)
if (mode == ControlMode::Velocity && (force_set || control_mode_ != ControlMode::Velocity)) {
bool torque_enabled = torque_enabled_;
if (torque_enabled) {
for (uint i = 0; i < joint_ids_.size(); ++i) {
if (!dynamixel_workbench_.setVelocityControlMode(joint_ids_[i], &log)) {
RCLCPP_INFO(rclcpp::get_logger(kDynamixelHardware), "Velocity control");
control_mode_ = ControlMode::Velocity;
} else if (
mode == ControlMode::Position && (force_set || control_mode_ != ControlMode::Position)) {
if (!dynamixel_workbench_.setPositionControlMode(joint_ids_[i], &log)) {
RCLCPP_INFO(rclcpp::get_logger(kDynamixelHardware), "Position control");
control_mode_ = ControlMode::Position;
} else if (control_mode_ != ControlMode::Velocity && control_mode_ != ControlMode::Position) {
RCLCPP_FATAL(
rclcpp::get_logger(kDynamixelHardware), "Only position/velocity control are implemented");
return_type DynamixelHardware::reset_command()
joints_[i].command.position = joints_[i].state.position;
joints_[i].command.velocity = 0.0;
joints_[i].command.effort = 0.0;
} // namespace dynamixel_hardware
#include "pluginlib/class_list_macros.hpp"
PLUGINLIB_EXPORT_CLASS(dynamixel_hardware::DynamixelHardware, hardware_interface::SystemInterface)
