Cannot call custom service messages
When I launched the service server, and tried to call it via rosservice call, the TAB-TAB does not work, it did not show any autocompletion. When I type a number for the variable duration, it raises an error as follows:
Here is my package structure:
Screenshot 2024-05-19 at 13.42.48
Here is the script for the server:
from my_custom_srv_msg_pkg.srv import MyCustomServiceMessage, MyCustomServiceMessageResponse
class MoveCircleServiceServer:
        rospy.init_node('move_circle_custom_service_server')
        self.pub = rospy.Publisher('/cmd_vel', Twist, queue_size=1)
        self.move_circle = Twist()
        self.service = rospy.Service('/move_bb8_in_circle_custom', MyCustomServiceMessage, self.callback) # create the Service called my_service with the defined callback
        rospy.loginfo("Service move_bb8_in_circle_custom Ready")
        rospy.on_shutdown(self.stop)
    def callback(self, request):
        rospy.loginfo("Service move_bb8_in_circle_custom has been called")
        self.move_circle.linear.x = 0.2
        self.move_circle.angular.z = 0.2
        end_time = rospy.Time.now() + rospy.Duration(request.duration)
        rate = rospy.Rate(10)
        while rospy.Time.now() < end_time:
            self.pub.publish(self.move_circle)
            rate.sleep()
        self.stop()
        rospy.loginfo("Finished service move_bb8_in_circle_custom")
        response = MyCustomServiceMessageResponse()
        response.success = True
        return response
    def spin(self):
        rospy.spin() # maintain the service open.
    def stop(self):
        rospy.loginfo("Stopping the robot...")
        self.pub.publish(self.move_circle)  # Publish the stop command
if __name__ == '__main__':
    service_server = MoveCircleServiceServer()
    try:
        service_server.spin()
        service_server.stop()
Here is the CmakeList.txt:
project(my_custom_srv_msg_pkg)
  rospy
  geometry_msgs
  message_generation
# catkin_python_setup()
##   your messages/services/actions (e.g. std_msgs, actionlib_msgs, ...).
## * In the file package.xml:
##   * add a build_depend tag for "message_generation"
##   * add a build_depend and a exec_depend tag for each package in MSG_DEP_SET
##   * If MSG_DEP_SET isn't empty the following dependency has been pulled in
##     but can be declared for certainty nonetheless:
##     * add a exec_depend tag for "message_runtime"
##   * add "message_generation" and every package in MSG_DEP_SET to
##     find_package(catkin REQUIRED COMPONENTS ...)
##   * add "message_runtime" and every package in MSG_DEP_SET to
##     catkin_package(CATKIN_DEPENDS ...)
##   * uncomment the add_*_files sections below as needed
##     and list every .msg/.srv/.action file to be processed
##   * uncomment the generate_messages entry below
##   * add every package in MSG_DEP_SET to generate_messages(DEPENDENCIES ...)
# add_message_files(
#   FILES
#   Message1.msg
#   Message2.msg
 add_service_files(
   FILES
   MyCustomServiceMessage.srv
# add_action_files(
#   FILES
#   Action1.action
#   Action2.action
 generate_messages(
   DEPENDENCIES
   geometry_msgs # Or other packages containing msgs
##   * add a build_depend and a exec_depend tag for "dynamic_reconfigure"
##   * add "dynamic_reconfigure" to
##   * uncomment the "generate_dynamic_reconfigure_options" section below
##     and list every .cfg file to be processed
#   cfg/DynReconf1.cfg
#   cfg/DynReconf2.cfg
catkin_package(
#  INCLUDE_DIRS include
#  LIBRARIES my_custom_src_msg_pkg
  CATKIN_DEPENDS message_runtime rospy geometry_msgs
#  DEPENDS system_lib
## Build ##
include_directories(
# include
  ${catkin_INCLUDE_DIRS}
## Declare a C++ library
# add_library(${PROJECT_NAME}
#   src/${PROJECT_NAME}/my_custom_src_msg_pkg.cpp
## Declare a C++ executable
# add_executable(${PROJECT_NAME}_node src/my_custom_src_msg_pkg_node.cpp)
#   ${catkin_LIBRARIES}
## Install ##
 catkin_install_python(PROGRAMS
   scripts/bb8_move_custom_service_server.py
   DESTINATION ${CATKIN_PACKAGE_BIN_DESTINATION}
#   RUNTIME DESTINATION ${CATKIN_PACKAGE_BIN_DESTINATION}
#   ARCHIVE DESTINATION ${CATKIN_PACKAGE_LIB_DESTINATION}
#   LIBRARY DESTINATION ${CATKIN_PACKAGE_LIB_DESTINATION}
#   RUNTIME DESTINATION ${CATKIN_GLOBAL_BIN_DESTINATION}
#   DESTINATION ${CATKIN_PACKAGE_INCLUDE_DESTINATION}
#   FILES_MATCHING PATTERN "*.h"
#   PATTERN ".svn" EXCLUDE
# install(FILES
#   # myfile1
#   # myfile2
#   DESTINATION ${CATKIN_PACKAGE_SHARE_DESTINATION}
## Testing ##
# catkin_add_gtest(${PROJECT_NAME}-test test/test_my_custom_src_msg_pkg.cpp)
#   target_link_libraries(${PROJECT_NAME}-test ${PROJECT_NAME})
# endif()
# catkin_add_nosetests(test)
Here is the package.xml:
<?xml version="1.0"?>
<package format="2">
  <name>my_custom_srv_msg_pkg</name>
  <version>0.0.0</version>
  <description>The my_custom_srv_msg_pkg package</description>
  <!-- Example:  -->
  <!--   BSD, MIT, Boost Software License, GPLv2, GPLv3, LGPLv2.1, LGPLv3 -->
  <license>TODO</license>
  <!-- Example: -->
  <!-- <url type="website">http://wiki.ros.org/my_custom_src_msg_pkg</url> -->
  <!-- Example: -->
  <!-- Examples: -->
  <!--   <depend>roscpp</depend> -->
  <!--   Note that this is equivalent to the following: -->
  <!--   <build_depend>roscpp</build_depend> -->
  <!--   <exec_depend>roscpp</exec_depend> -->
  <!--   <build_depend>message_generation</build_depend> -->
  <!--   <build_export_depend>message_generation</build_export_depend> -->
  <!--   <buildtool_depend>catkin</buildtool_depend> -->
  <!--   <exec_depend>message_runtime</exec_depend> -->
  <!--   <test_depend>gtest</test_depend> -->
  <!--   <doc_depend>doxygen</doc_depend> -->
  <build_depend>geometry_msgs</build_depend>
  <build_export_depend>geometry_msgs</build_export_depend>
  <exec_depend>geometry_msgs</exec_depend>
  <export>
  </export>
</package>
Oh I realized that it is still because I use two webshells and forgot to source the second shell.
This issue has been solved. No need to reply :blush:
Hi @min.wang.1997.01.13,
That is what I thought, that you forgot to source ~/catkin_ws/devel/setup.bash the terminal where the commands were being executed.
I’m glad you managed to find it by yourself.
