I was following the instructions for section 4.6: Custom service interface, and the following error popped up, it worked if I created a new package only for that service, is it possible the issue is with the package also has another custom interface: Age.msg?
user:~/ros2_ws$ colcon build --packages-select custom_interfaces
Starting >>> custom_interfaces
--- stderr: custom_interfaces
CMake Error at /opt/ros/foxy/share/rosidl_cmake/cmake/rosidl_generate_interfaces.cmake:213 (add_custom_target):
add_custom_target cannot create target "custom_interfaces" because another
target with the same name already exists. The existing target is a custom
target created in source directory
"/home/user/ros2_ws/src/custom_interfaces". See documentation for policy
CMP0002 for more details.
CMakeLists.txt:41 (rosidl_generate_interfaces)
make: *** [Makefile:748: cmake_check_build_system] Error 1
Failed <<< custom_interfaces [1.96s, exited with code 2]
Summary: 0 packages finished [2.17s]
1 package failed: custom_interfaces
1 package had stderr output: custom_interfaces
