tellez, thanks for the response. My apology for the “very” late response. I use Chrome as a browser. However, I now have a new problem see screen shot below:
There is an error I now need to clear.
The problem in your image is that you are trying to launch a launch file named move
and that doesn’t exist.
You have a problem there: move
is not a proper name for a launch file. Launch files should end with .launch
. So the error indicates that a launch file named move
doesn’t exist, which makes perfect sense.
Please check two things:
roslaunch
command should be calling a proper launch
filepublisher_example
