Cannot move Summit-XL with turtlebot_teleop
I created a package as the tutorial suggests, that launches the turtlebot_teleop_keyboard node, remapping the topic turtlebot_teleop_keyboard/cmd_vel to /summit_xl_control/cmd_vel. While, the topic remaps correctly, only blank messages are being published to it, even if I press the correct keys. This is what I get when echoing the topic.
linear:
x: 0.0
y: 0.0
z: 0.0
angular:
x: 0.0
y: 0.0
z: 0.0
even if the terminal in which I launched the node reads this:
currently: speed 0.2 turn 1
currently: speed 0.2 turn 1.1
currently: speed 0.2 turn 1.21
currently: speed 0.2 turn 1.331
currently: speed 0.2 turn 1.4641
currently: speed 0.2 turn 1.61051
currently: speed 0.2 turn 1.771561
I suspect there must be something wrong with either the CMakeLists.txt or package.xml files, probably the message_runtime, or message_generation dependencies. If I could get a bit of help to understand how these dependencies work, I would appreciate it.
This is my CMakeLists.txt
project(my_summit_xl_tools)
  rospy
  std_msgs
  summit_xl_gazebo
  message_generation
  geometry_msgs
  turtlebot_teleop
# catkin_python_setup()
##   your messages/services/actions (e.g. std_msgs, actionlib_msgs, ...).
## * In the file package.xml:
##   * add a build_depend tag for "message_generation"
##   * add a build_depend and a exec_depend tag for each package in MSG_DEP_SET
##   * If MSG_DEP_SET isn't empty the following dependency has been pulled in
##     but can be declared for certainty nonetheless:
##     * add a exec_depend tag for "message_runtime"
##   * add "message_generation" and every package in MSG_DEP_SET to
##     find_package(catkin REQUIRED COMPONENTS ...)
##   * add "message_runtime" and every package in MSG_DEP_SET to
##     catkin_package(CATKIN_DEPENDS ...)
##   * uncomment the add_*_files sections below as needed
##     and list every .msg/.srv/.action file to be processed
##   * uncomment the generate_messages entry below
##   * add every package in MSG_DEP_SET to generate_messages(DEPENDENCIES ...)
# add_message_files(
#   FILES
#   Message1.msg
#   Message2.msg
# add_service_files(
#   FILES
#   Service1.srv
#   Service2.srv
# add_action_files(
#   FILES
#   Action1.action
#   Action2.action
 generate_messages(
   DEPENDENCIES
   std_msgs
   geometry_msgs
##   * add a build_depend and a exec_depend tag for "dynamic_reconfigure"
##   * add "dynamic_reconfigure" to
##   * uncomment the "generate_dynamic_reconfigure_options" section below
##     and list every .cfg file to be processed
#   cfg/DynReconf1.cfg
#   cfg/DynReconf2.cfg
catkin_package(
#  INCLUDE_DIRS include
#  LIBRARIES my_summit_xl_tools
  CATKIN_DEPENDS rospy message_runtime geometry_msgs std_msgs turtlebot_teleop
  #DEPENDS system_lib
## Build ##
include_directories(
# include
  ${catkin_INCLUDE_DIRS}
## Declare a C++ library
# add_library(${PROJECT_NAME}
#   src/${PROJECT_NAME}/my_summit_xl_tools.cpp
## Declare a C++ executable
# add_executable(${PROJECT_NAME}_node src/my_summit_xl_tools_node.cpp)
#   ${catkin_LIBRARIES}
## Install ##
#   scripts/my_python_script
#   DESTINATION ${CATKIN_PACKAGE_BIN_DESTINATION}
#   RUNTIME DESTINATION ${CATKIN_PACKAGE_BIN_DESTINATION}
#   ARCHIVE DESTINATION ${CATKIN_PACKAGE_LIB_DESTINATION}
#   LIBRARY DESTINATION ${CATKIN_PACKAGE_LIB_DESTINATION}
#   RUNTIME DESTINATION ${CATKIN_GLOBAL_BIN_DESTINATION}
#   DESTINATION ${CATKIN_PACKAGE_INCLUDE_DESTINATION}
#   FILES_MATCHING PATTERN "*.h"
#   PATTERN ".svn" EXCLUDE
 install(DIRECTORY
    launch
#   # myfile2
   DESTINATION ${CATKIN_PACKAGE_SHARE_DESTINATION}
## Testing ##
# catkin_add_gtest(${PROJECT_NAME}-test test/test_my_summit_xl_tools.cpp)
#   target_link_libraries(${PROJECT_NAME}-test ${PROJECT_NAME})
# endif()
# catkin_add_nosetests(test)
This is my package.xml file:
<?xml version="1.0"?>
<package format="2">
  <name>my_summit_xl_tools</name>
  <version>0.0.0</version>
  <description>The my_summit_xl_tools package</description>
  <!-- Example:  -->
  <!--   BSD, MIT, Boost Software License, GPLv2, GPLv3, LGPLv2.1, LGPLv3 -->
  <license>TODO</license>
  <!-- Example: -->
  <!-- <url type="website">http://wiki.ros.org/my_summit_xl_tools</url> -->
  <!-- Example: -->
  <!-- Examples: -->
  <!--   <depend>roscpp</depend> -->
  <!--   Note that this is equivalent to the following: -->
  <!--   <build_depend>roscpp</build_depend> -->
  <!--   <exec_depend>roscpp</exec_depend> -->
  <!--   <build_depend>message_generation</build_depend> -->
  <!--   <build_export_depend>message_generation</build_export_depend> -->
  <!--   <buildtool_depend>catkin</buildtool_depend> -->
  <!--   <exec_depend>message_runtime</exec_depend> -->
  <!--   <test_depend>gtest</test_depend> -->
  <!--   <doc_depend>doxygen</doc_depend> -->
  <build_depend>summit_xl_gazebo</build_depend>
  <build_depend> geometry_msgs </build_depend>
  <build_depend> std_msgs </build_depend>
  <build_depend> turtlebot_teleop </build_depend>
  <build_export_depend> turtlebot_teleop </build_export_depend>
  <exec_depend> rospy </exec_depend>
  <exec_depend> summit_xl_gazebo </exec_depend>
  <exec_depend> message_runtime </exec_depend>
  <exec_depend> geometry_msgs </exec_depend>
  <exec_depend> std_msgs </exec_depend>
  <exec_depend> turtlebot_teleop </exec_depend>
  <export>
  </export>
</package>
Thank you in advance!
Hi, welcome to the community! Sorry for the delay.
I think you will have an issue because the turtlebot_teleop_keyboard is not the “generic” teleop. What you can do is first, check the exact name for your cmd_vel topic with:
rostopic list
Then, you can use the following command:
rosrun teleop_twist_keyboard teleop_twist_keyboard.py cmd_vel:=<your_cmd_vel_topic>
This is a teleop node that can work for any robot that uses cmd_vel, and the last part, cmd_vel:=<your_cmd_vel_topic> is where you are remapping the topic to fit whatever your robot is listening to. Make sure to replace it with the name of the topic you found earlier.
