I have added the obstacle cone and as shown in the photos below, and successfully managed to navigate the robot to go behind the cone while avoiding it (Goal Suceeded).
Before:
After:
However, I notice that when I configure my local costmap, it does not look like as it should as shown by the notebook in the image below:
Is there anything I am missing? Below is my controller.yaml file:
controller_server:
ros__parameters:
use_sim_time: True
controller_frequency: 10.0
min_y_velocity_threshold: 0.5
failure_tolerance: 0.3
progress_checker_plugin: “progress_checker”
goal_checker_plugins: [“general_goal_checker”]
controller_plugins: [“FollowPath”]
# Progress checker parameters
progress_checker:
required_movement_radius: 0.5
movement_time_allowance: 10.0
# Goal checker parameters
general_goal_checker:
stateful: True
xy_goal_tolerance: 0.25
yaw_goal_tolerance: 0.25
# DWB parameters
FollowPath:
min_vel_x: 0.0
min_vel_y: 0.0
max_vel_x: 0.26
max_vel_y: 0.0
max_vel_theta: 1.0
min_speed_xy: 0.0
max_speed_xy: 0.26
min_speed_theta: 0.0
acc_lim_x: 2.5
acc_lim_y: 0.0
acc_lim_theta: 3.2
decel_lim_x: -2.5
decel_lim_y: 0.0
decel_lim_theta: -3.2
vx_samples: 20
vy_samples: 5
vtheta_samples: 20
sim_time: 1.7
linear_granularity: 0.05
angular_granularity: 0.025
transform_tolerance: 0.2
trans_stopped_velocity: 0.25
stateful: True
BaseObstacle.scale: 0.02
PathAlign.scale: 32.0
GoalAlign.scale: 24.0
PathDist.scale: 32.0
GoalDist.scale: 24.0
RotateToGoal.scale: 32.0
local_costmap:
local_costmap:
ros__parameters:
update_frequency: 5.0
publish_frequency: 2.0
global_frame: odom
robot_base_frame: base_link
use_sim_time: True
rolling_window: true
width: 1
height: 1
resolution: 0.05
robot_radius: 0.15
plugins: [“voxel_layer”, “inflation_layer”]
inflation_layer:
plugin: “nav2_costmap_2d::InflationLayer”
cost_scaling_factor: 3.0
inflation_radius: 0.35
voxel_layer:
plugin: “nav2_costmap_2d::VoxelLayer”
enabled: True
publish_voxel_map: True
origin_z: 0.0
z_resolution: 0.05
z_voxels: 16
max_obstacle_height: 2.0
mark_threshold: 0
observation_sources: scan
scan:
topic: /scan
clearing: True
marking: True
data_type: “LaserScan”
raytrace_max_range: 3.0
raytrace_min_range: 0.0
obstacle_max_range: 2.5
obstacle_min_range: 0.0
static_layer:
map_subscribe_transient_local: True
always_send_full_costmap: True
