Just your screen capture cannot help us understand what is the problem.
Please indicate all the steps that you took before obtaining the rviz sceenshot you showed. For example:
- Did you create a map of the environment?
- Did you launch the
localization_serverproperly configured (the one that also launches themap_server? - What are the outputs of the terminals?
Please provide as much explanation and screenshots as possible
I am also getting the error that the map is not received under the message even though I set the topic as /map and I can see that it is active via the ros2 node list
