I copied the solution, however, while using the catkin_make,there was something wrong.
How to fix this problem?
Maybe you have trouble in CMakeFile.txt?
Copying the solution does not guarantee that everything will work. The solution is there as a guide, not for copying.
You should carefully follow the notes and ensure that every file has been created as indicated.
Thanks a lot, after checking the full filename ,I solved this problem
