Can't get real turtle bot to move
Hello there,
I booked some consecutive time slots to test my rosject but I stuck the turtle bot in the wall and I can’t move it anymore: I tryes the joystick, the key teleop ros1, keyteleop+ bridge ros2.
Is it possible to that there is a problem?
Thank you for your help.
Hi, let me take a look and I’ll get back to you.
It seems like the wheels failed when the robot ran into the wall. You should be able to use it fine now.
