why with cartographer we use .lua for configuration not .yaml files?
In ros1 we used .yaml files to add the parameters to the launch file.
That is the format that the creators of the package decided to use. This is probably due because the creators created Cartographer initially without any use with ROS, but then decided to integrate it with ROS, so they used what was already being used.
