Catkin_make error
hello I can’t fix the error of catkin_make. I am doing rosject of “ROS basics in 5 days” and when I do the catkin_make I get the following error:
“”"CMake Error at /home/user/catkin_ws/build/turtlebot3_move/cmake/turtlebot3_move-genmsg.cmake:3 (message):
Could not find messages which
‘/home/user/catkin_ws/devel/share/turtlebot3_move/msg/OdomRecordMsgAction.msg’
depends on. Did you forget to specify generate_messages(DEPENDENCIES …)?
Cannot locate message [Point] in package [turtlebot3_move] with paths
[[’/home/user/catkin_ws/devel/share/turtlebot3_move/msg’]]
/opt/ros/noetic/share/genmsg/cmake/genmsg-extras.cmake:307 (include)
turtlebot3_move/CMakeLists.txt:30 (generate_messages)
– Configuring incomplete, errors occurred!"""
following is CMakeLists.txt
project(turtlebot3_move)
  rospy
  actionlib_msgs
  std_msgs
  message_generation
# add_message_files(
#   FILES
#   Message1.msg
#   Message2.msg
add_service_files(
    FILES
    MoveInSquare.srv
#   Service1.srv
#   Service2.srv
add_action_files(
    FILES
    OdomRecordMsg.action
generate_messages(
    DEPENDENCIES
	std_msgs
    actionlib_msgs
catkin_package(
    CATKIN_DEPENDS
    rospy
    message_runtime
	actionlib_msgs
#  DEPENDS system_lib
include_directories(
# include
    ${catkin_INCLUDE_DIRS}
and this is my package.xml
<?xml version="1.0"?>
<package format="2">
  <name>turtlebot3_move</name>
  <version>0.0.0</version>
  <description>The turtlebot3_move package</description>
  <!-- Example:  -->
  <!--   BSD, MIT, Boost Software License, GPLv2, GPLv3, LGPLv2.1, LGPLv3 -->
  <license>TODO</license>
  <!-- Example: -->
  <!-- <url type="website">http://wiki.ros.org/turtlebot3_move</url> -->
  <!-- Example: -->
  <!-- Examples: -->
  <!--   <depend>roscpp</depend> -->
  <!--   Note that this is equivalent to the following: -->
  <!--   <build_depend>roscpp</build_depend> -->
  <!--   <exec_depend>roscpp</exec_depend> -->
  <!--   <build_depend>message_generation</build_depend> -->
  <!--   <build_export_depend>message_generation</build_export_depend> -->
  <!--   <buildtool_depend>catkin</buildtool_depend> -->
  <!--   <exec_depend>message_runtime</exec_depend> -->
  <!--   <test_depend>gtest</test_depend> -->
  <!--   <doc_depend>doxygen</doc_depend> -->
  <build_depend>actionlib</build_depend>
  <build_depend>actionlib_msgs</build_depend>
  <build_export_depend>actionlib</build_export_depend>
  <build_export_depend>actionlib_msgs</build_export_depend>
  <exec_depend>actionlib</exec_depend>
  <exec_depend>actionlib_msgs</exec_depend>
  <export>
  </export>
</package>
@Joseph1001 hey can you please take a look at my problem please?
Hi @ptgh ,good to hear from you again. I will try my hand at this, but just so you know, modifying Cmake files and the XML file is not my strong suit. :sweat_smile: :
You action Msg file:
Now the error mentioned is saying that the program is not able to find the package holding Point, called geometry_msgs since you have not mentioned it under generate_messages().
Just add geometry_msgs package to the following:
Add to find_package so that the program can find the package:
  rospy
  actionlib_msgs
  std_msgs
  message_generation
  geometry_msgs
Add to generate_messages, since it holds all the packages needed for message generation.
generate_messages(
    DEPENDENCIES
	std_msgs
    actionlib_msgs
    geometry_msgs
Add below lines in the XML file:
<build_depend>geometry_msgs</build_depend>
<build_export_depend>geometry_msgs</build_export_depend>
<exec_depend>geometry_msgs</exec_depend>
Give this a try and let me know how it goes.
hahaha :joy: many thanks for your reply
actually following are the current files and new error
action file
Point[] list_of_odoms
float32 current_total
cmakelists.txt file
project(turtlebot3_move_test)
  rospy
  std_msgs
  actionlib_msgs
  message_generation
  sensor_msgs
  geometry_msgs
# catkin_python_setup()
##   your messages/services/actions (e.g. std_msgs, actionlib_msgs, ...).
## * In the file package.xml:
##   * add a build_depend tag for "message_generation"
##   * add a build_depend and a exec_depend tag for each package in MSG_DEP_SET
##   * If MSG_DEP_SET isn't empty the following dependency has been pulled in
##     but can be declared for certainty nonetheless:
##     * add a exec_depend tag for "message_runtime"
##   * add "message_generation" and every package in MSG_DEP_SET to
##     find_package(catkin REQUIRED COMPONENTS ...)
##   * add "message_runtime" and every package in MSG_DEP_SET to
##     catkin_package(CATKIN_DEPENDS ...)
##   * uncomment the add_*_files sections below as needed
##     and list every .msg/.srv/.action file to be processed
##   * uncomment the generate_messages entry below
##   * add every package in MSG_DEP_SET to generate_messages(DEPENDENCIES ...)
#   FILES
#   Message1.msg
#   Message2.msg
 add_service_files(
   FILES
   MoveInSquare.srv
#   Service2.srv
 add_action_files(
   FILES
#   Action2.action
 generate_messages(
   DEPENDENCIES
   std_msgs
   actionlib_msgs
   sensor_msgs
   geometry_msgs
catkin_package(
#  INCLUDE_DIRS include
#  LIBRARIES turtlebot3_move_test
  CATKIN_DEPENDS rospy message_runtime
# include
and package.xml
  <name>turtlebot3_move_test</name>
  <description>The turtlebot3_move_test package</description>
  <!-- Example:  -->
  <!-- Example: -->
  <!-- <url type="website">http://wiki.ros.org/turtlebot3_move_test</url> -->
  <!-- Example: -->
  <!-- Examples: -->
  <build_depend>sensor_msgs</build_depend>
  <build_export_depend>sensor_msgs</build_export_depend>
  <exec_depend>sensor_msgs</exec_depend>
  <export>
  </export>
</package>
the error it shows says :
`File “/opt/ros/noetic/lib/python3/dist-packages/genmsg/deps.py”, line 50, in find_msg_dependencies_with_type
raise genmsg.MsgGenerationException(“Cannot read .msg for %s: %s”%(full_type_name, str(e)))
genmsg.base.MsgGenerationException: Cannot read .msg for turtlebot3_move_test/OdomRecordMsgAction: /home/user/catkin_ws/devel/share/turtlebot3_move_test/msg/OdomRecordMsgGoal.msg: Invalid declaration: OdomRecordMsg.action
CMake Error at /opt/ros/noetic/share/catkin/cmake/safe_execute_process.cmake:11 (message):
execute_process(/home/user/catkin_ws/build/catkin_generated/env_cached.sh
“/usr/bin/python3” “/usr/lib/python3/dist-packages/em.py” “–raw-errors”
“-F”
“/home/user/catkin_ws/build/turtlebot3_move_test/cmake/turtlebot3_move_test-genmsg-context.py”
“-o”
“/home/user/catkin_ws/build/turtlebot3_move_test/cmake/turtlebot3_move_test-genmsg.cmake”
“/opt/ros/noetic/share/genmsg/cmake/pkg-genmsg.cmake.em”) returned error
code 1
/opt/ros/noetic/share/catkin/cmake/em_expand.cmake:25 (safe_execute_process)
/opt/ros/noetic/share/genmsg/cmake/genmsg-extras.cmake:303 (em_expand)
turtlebot3_move_test/CMakeLists.txt:77 (generate_messages)
See also “/home/user/catkin_ws/build/CMakeFiles/CMakeOutput.log”.
See also “/home/user/catkin_ws/build/CMakeFiles/CMakeError.log”.
make: *** [Makefile:320: cmake_check_build_system] Error 1
Invoking “make cmake_check_build_system” failed`
@ptgh ,unfortunatly, i am not able to figure it out, but i take it that the errors from the previous post are resolved.
Let me forward your query to the @staff ,they are more experienced in section.
Instead of the above line in your custom action file, use the following:
geometry_msgs/Point[] list_of_odoms
thank you for your reply but the problem persists with the following error.
  "/usr/bin/python3" "/usr/lib/python3/dist-packages/em.py" "--raw-errors"
  "-F"
  "/home/user/catkin_ws/build/turtlebot3_move_test/cmake/turtlebot3_move_test-genmsg-context.py"
  "-o"
  "/home/user/catkin_ws/build/turtlebot3_move_test/cmake/turtlebot3_move_test-genmsg.cmake"
  "/opt/ros/noetic/share/genmsg/cmake/pkg-genmsg.cmake.em") returned error
  code 1
  turtlebot3_move_test/CMakeLists.txt:26 (generate_messages)
-- Configuring incomplete, errors occurred!
See also "/home/user/catkin_ws/build/CMakeFiles/CMakeOutput.log".
See also "/home/user/catkin_ws/build/CMakeFiles/CMakeError.log".
Invoking "cmake" failed
oh I found that I changed .srv file to
MoveInSquare.srv
bool complete
instead of the following one:
bool complete
the problem is solved
@Joseph1001 @bayodesegun many thanks.
This topic was automatically closed 24 hours after the last reply. New replies are no longer allowed.
