Thank you for your reply. I am trying to solve the problem. I have learned a lot of things from this path.Today it is working as expected. But I am facing another problem. When I am trying to create a custom action message, It is giving me an error during the catkin_make command. I have never seen the building process like the final exam. So, I am actually confused here. The error is like this one.
CMake Error at /opt/ros/kinetic/share/catkin/cmake/safe_execute_process.cmake:11 (message):
execute_process(/home/user/catkin_ws/build/catkin_generated/env_cached.sh
"/usr/bin/python2" "/usr/bin/empy" "--raw-errors" "-F"
"/home/user/catkin_ws/build/catkin_generated/order_packages.py" "-o"
"/home/user/catkin_ws/build/catkin_generated/order_packages.cmake"
"/opt/ros/kinetic/share/catkin/cmake/em/order_packages.cmake.em") returned
error code 1
/opt/ros/kinetic/share/catkin/cmake/em_expand.cmake:25 (safe_execute_process)
/opt/ros/kinetic/share/catkin/cmake/catkin_workspace.cmake:35 (em_expand)
CMakeLists.txt:63 (catkin_workspace)
-- Configuring incomplete, errors occurred!
See also "/home/user/catkin_ws/build/CMakeFiles/CMakeOutput.log".
See also "/home/user/catkin_ws/build/CMakeFiles/CMakeError.log".
Invoking "cmake" failed
My CMakeLists.txt is
project(path_exam)
rospy
actionlib_msgs
geometry_msgs
# catkin_python_setup()
## * In the file package.xml:
# add_message_files(
# FILES
# Message1.msg
# Message2.msg
# add_service_files(
# FILES
# Service1.srv
# Service2.srv
add_action_files(
FILES
RecordOdom.action
# Action1.action
# Action2.action
generate_messages(
DEPENDENCIES
actionlib_msgs
geometry_msgs
# cfg/DynReconf1.cfg
# cfg/DynReconf2.cfg
catkin_package(
# INCLUDE_DIRS include
# LIBRARIES path_exam
CATKIN_DEPENDS rospy geometry_msgs
# DEPENDS system_lib
## Build ##
include_directories(
# include
${catkin_INCLUDE_DIRS}
## Declare a C++ library
# add_library(${PROJECT_NAME}
# src/${PROJECT_NAME}/path_exam.cpp
## Declare a C++ executable
# add_executable(${PROJECT_NAME}_node src/path_exam_node.cpp)
# ${catkin_LIBRARIES}
## Install ##
# scripts/my_python_script
# PATTERN ".svn" EXCLUDE
# install(FILES
# # myfile1
# # myfile2
## Testing ##
# catkin_add_gtest(${PROJECT_NAME}-test test/test_path_exam.cpp)
# endif()
# catkin_add_nosetests(test)
My package.xml file is
<?xml version="1.0"?>
<package format="2">
<name>path_exam</name>
<version>0.0.0</version>
<description>The path_exam package</description>
<!-- Example: -->
<!-- BSD, MIT, Boost Software License, GPLv2, GPLv3, LGPLv2.1, LGPLv3 -->
<license>TODO</license>
<!-- Example: -->
<!-- <url type="website">http://wiki.ros.org/path_exam</url> -->
<!-- Example: -->
<!-- Examples: -->
<!-- <depend>roscpp</depend> -->
<!-- Note that this is equivalent to the following: -->
<!-- <build_depend>roscpp</build_depend> -->
<!-- <exec_depend>roscpp</exec_depend> -->
<!-- <build_depend>message_generation</build_depend> -->
<!-- <build_export_depend>message_generation</build_export_depend> -->
<!-- <buildtool_depend>catkin</buildtool_depend> -->
<!-- <exec_depend>message_runtime</exec_depend> -->
<!-- <test_depend>gtest</test_depend> -->
<!-- <doc_depend>doxygen</doc_depend> -->
<build_depend>actionlib_msgs</build_depend>
<build_depend>geometry_msgs</build_depend>
<build_export_depend>geometry_msgs</build_export_depend>
<exec_depend>geometry_msgs</exec_depend>
<export>
</export>
</package>
what should I need to do in this situation?
