I tried to catkin_make my package, and it hangs after the – BUILD_SHARED_LIBS is on, as shown in the image below. Does anyone know what is the issue? Thanks!
Are you allowing time enough to compile? It looks like you interrupted the process with Ctrl+C before it could finish.
Also, I can see you created another ROS catkin workspace named catkin_robot. Have you checked that there is nothing wrong in the default catkin_ws?
Thanks for your reply.
The program runs successfully on my own VM. I interrupted it because it takes much time and just hangs. I didn’t change the default catkin_ws and it is empty in the /src folder.
Hi!
I’m in exactly the same situation in melodic. It is recommended that you use kinetic or another distribution.
