In chapter 2 of the ROS Autonomous Vehicle course we have to make the vehicle move through waypoints. So I began creating a new package for my code, executed catkin_make and I got the following error:
Invoking “make -j36 -l36” failed
I removed my package, incase the issue is my code executed catkin_make again but I still got the same error.
Can someone help me resolve this, please ?
Hi @adeoduye ,
Welcome to the Community!
Could you please paste here the whole text of the error? The error message most times gives you a hint of what is wrong.
lyur3
November 16, 2020, 5:30pm
3
I encounted the same problem, in 5 days for ROS (C++). When I created a package and use catkin_make, it shows:
user:~/catkin_ws$ catkin_make
Running command: “make cmake_check_build_system” in “/home/user/catkin_ws/build”
Running command: “make -j36 -l36” in “/home/user/catkin_ws/build”
[ 0%] Built target std_msgs_generate_messages_lisp
[ 0%] Built target std_msgs_generate_messages_eus
[ 0%] Built target roscpp_generate_messages_lisp
[ 0%] Built target std_msgs_generate_messages_nodejs
[ 0%] Built target roscpp_generate_messages_nodejs
[ 0%] Built target rosgraph_msgs_generate_messages_lisp
[ 0%] Built target rosgraph_msgs_generate_messages_py
[ 0%] Built target roscpp_generate_messages_eus
[ 0%] Built target std_msgs_generate_messages_cpp
[ 0%] Built target rosgraph_msgs_generate_messages_cpp
[ 0%] Built target roscpp_generate_messages_cpp
[ 0%] Built target rosgraph_msgs_generate_messages_nodejs
[ 0%] Built target rosgraph_msgs_generate_messages_eus
[ 0%] Built target roscpp_generate_messages_py
[ 0%] Built target std_msgs_generate_messages_py
make[2]: *** No rule to make target ‘my_package/CMakeFiles/simple.dir/build’. Stop.
CMakeFiles/Makefile2:921: recipe for target ‘my_package/CMakeFiles/simple.dir/all’ failed
make[1]: *** [my_package/CMakeFiles/simple.dir/all] Error 2
Makefile:138: recipe for target ‘all’ failed
make: *** [all] Error 2
