Hello @d.lancaster1,
This issue should be solved as for today. If it’s not, please let me know.
As @albertoezquerro mentioned, this should be solved as I can see that your files are there. It’s possible that there was some delay with the download the last time you tried. Please let us know if you have the issue again.
BR,
Hello @albertoezquerro
I have the same issue! In “Path Planning Basics” I cannot see the example and solution files inside src! Please help
@otoware21
Unless it is mentioned in the notes, you won’t find the example and solution files in src. Generally, that folder contains the file you have created yourself, as you take the course. So if you have not created any, it would be empty.
