I’ve finished “Code foundation of ROS” with account name matthew.gnwn23 connected to matthew.gnwn23@gmail.com, but the certificate hasn’t come out yet. Can you pls help with it, thanks.
I think you have to finish the project associated to the course first and post it on youtube.
The Code Foundation for ROS certificate has been discontinued.
Each course within that path now offers a separate certificate. To get the certificate for each course, you must complete and present the Real Robot Project specified in the course’s notebook.
Matthew,
for each one of those courses, you need to do a project. Open the course you want to have the certificate, follow it through and at some point you will see that the course tells you to open a project. That is the project you need to do to get the certificate. The project itself contains the instructions to complete it and to test it remotely with our real robots. Also explains how to request the presentation so you can present your project to the world and get the certificate (if you pass it).
Check this Youtube channel to see other students project presentations: https://www.youtube.com/@becomingarosdeveloper6394
