Question 1: The robot is moving but does not seem to be learning, almost always with negative rewards while running for the first 30 minutes and then shows “[ERROR] … Failed to fetch current robot state”. Did the robot learn when you guys are test running it and at how many steps and episode was this learning behavior observed? If not, how do you get it to learn?
Question 2: This line “state = self.env.reset()” restore the cube and robot to their original position but does not restore the robot arm to its original configuration / posture. Do you need to? If yes, how do you do it?
Thank you.
