I tried to solve this quiz and having issue solving this bug, please help, while I am executing the actions_quiz, it is giving error:, I have tried both ways as suggested in earlier forum, still issue not resolving
ImportError: cannot import name ‘CustomActionMsgFeedback’ from ‘actions_quiz.msg’ (unknown location)
Adding CMakeList.txt file:
project(actions_quiz)
std_msgs
actionlib_msgs
Generate services in the ‘srv’ folder
add_service_files(
FILES
Service1.srv
Service2.srv
Generate actions in the ‘action’ folder
add_action_files(
FILES
CustomActionMsg.action
Generate added messages and services with any dependencies listed here
generate_messages(
DEPENDENCIES
std_msgs
actionlib_msgs
catkin_package(
INCLUDE_DIRS include
LIBRARIES actions_quiz
CATKIN_DEPENDS actionlib_msgs rospy std_msgs
#CATKIN_DEPENDS actionlib_msgs rospy std_msgs
DEPENDS system_lib
include_directories(
${catkin_INCLUDE_DIRS}
user
<build_depend>actionlib</build_depend>
<build_depend>actionlib_msgs</build_depend>
<build_export_depend>actionlib</build_export_depend>
<build_export_depend>actionlib_msgs</build_export_depend>
<exec_depend>actionlib</exec_depend>
<exec_depend>actionlib_msgs</exec_depend>
Hi @Pankaj82 ,
You need to add actionlib in your CMakeLists.txt as shown below:
actionlib
actionlib_msgs
rospy
std_msgs
catkin_package(
# INCLUDE_DIRS include
# LIBRARIES actions_quiz
CATKIN_DEPENDS actionlib actionlib_msgs rospy std_msgs
# DEPENDS system_lib
You need to import
from actions_quiz.msg import (CustomActionMsgAction,
CustomActionMsgActionFeedback,
CustomActionMsgActionResult)
instead of using
from actions_quiz.msg import (CustomActionMsgFeedback,
CustomActionMsgResult,
CustomActionMsgAction)
Do these changes and your package will work.
Thanks, I am able to complete my action_quiz. One more question, during my first trial i try to submit my quiz, and i was not able to fix this issue as a result Quiz bot rated me 6, but later I tried to resubmit and quizbot is not accepting my assignment again? what should I do.
Hi @Pankaj82 ,
I think that is some sort of glitch. Try to refresh the page of the course and try to submit again.
This time it should work. If this is your third attempt and still fails, let us know immediately.
Do not exhaust your 5 attempts - otherwise you will not be able to finish the quiz.
Also don’t look into the answer/solution.
Hi Girish, I tried already 3 times, it is not allowing me to submit again, first attempt I got 6 out 10. my course name is ROS in 5 Days
@Pankaj82 You cannot submit anymore because you viewed the solution in your last attempt.
Now you have to do the final assessment, which is the live presentation of the Real Robot Project (mentioned after the ROS Topics - Subscribers and Messages unit).
