I think that we should have a feature to view solutions again.
Sometimes I want to see it, the solution can be a template for the beginners to review many times.
Thanks
You should vote the post to increase the chances of getting it implemented. The vote button is beside the post title.
This feature has been implemented
You will be able to view the solution under the following circumstances:
- You had a score of 10.0/10.0 in any attempt.
- You have used up all your attempts.
- You have previously viewed the solution (and can no longer submit the code for grading).
