after executing catkin_make i get
generate_messages at CmakeLists looks like that
Tried to remove build and devel, catkin_make --only-pkg-with-deps, copying directly from example 6.8, nothing helped
Hi @belkloilya ,
Welcome to this Community!
It seems that you have not exactly followed the instructions. I could infer this looking at your CMakeLists.txt file.
So what you have to do is:
message_generation under find_package in your CMakeLists.txt file, like this:find_package(catkin REQUIRED COMPONENTS
rospy
std_msgs
message_generation # this package is important for custom messages
add_service_files() in CMakeLists.txt
add_service_files(
FILES
MyCustomServiceMessage.srv
generate_messages() looks correct. You do not have to modify this.generate_messages(
DEPENDENCIES
std_msgs # Or other packages containing msgs
package.xml file:rospy and std_msgs) <build_depend>message_generation</build_depend>
Once you have all these, you should be able to re-build the package without any problems.
Let me know if this solves your problem.
PS: If the custom message is not properly built, then you cannot run any script with rosrun that uses the custom message. It will produce error.
Thank you so much! It finally works!
