Hello I am following the Openai - Training a Fetch Robot Part 1 (Exercise 7.3)
I created 4 new services messages under the srv
folder under fetch_train
package.
I edited the CMakeList.txt and Package.xml which are as follows
CMakeLists.txt
project(fetch_train)
rospy
std_msgs
message_generation
# catkin_python_setup()
## * In the file package.xml:
# add_message_files(
# FILES
# Message1.msg
# Message2.msg
add_service_files(
FILES
EePose.srv
EeRpy.srv
EeTraj.srv
JointTraj.srv
# add_action_files(
# FILES
# Action1.action
# Action2.action
generate_messages(
DEPENDENCIES
std_msgs
# Or other packages containing msgs
# cfg/DynReconf1.cfg
# cfg/DynReconf2.cfg
catkin_package(
# INCLUDE_DIRS include
# LIBRARIES fetch_train
CATKIN_DEPENDS rospy
# DEPENDS system_lib
## Build ##
include_directories(
# include
${catkin_INCLUDE_DIRS}
## Declare a C++ library
# add_library(${PROJECT_NAME}
# src/${PROJECT_NAME}/fetch_train.cpp
## Declare a C++ executable
# add_executable(${PROJECT_NAME}_node src/fetch_train_node.cpp)
# ${catkin_LIBRARIES}
## Install ##
# install(PROGRAMS
# scripts/my_python_script
# PATTERN ".svn" EXCLUDE
# install(FILES
# # myfile1
# # myfile2
## Testing ##
# catkin_add_gtest(${PROJECT_NAME}-test test/test_fetch_train.cpp)
# endif()
# catkin_add_nosetests(test)
and package.xml
as,
<?xml version="1.0"?>
<package format="2">
<name>fetch_train</name>
<version>0.0.0</version>
<description>The fetch_train package</description>
<!-- Example: -->
<!-- BSD, MIT, Boost Software License, GPLv2, GPLv3, LGPLv2.1, LGPLv3 -->
<license>TODO</license>
<!-- Example: -->
<!-- <url type="website">http://wiki.ros.org/fetch_train</url> -->
<!-- Example: -->
<!-- Examples: -->
<!-- <depend>roscpp</depend> -->
<!-- Note that this is equivalent to the following: -->
<!-- <build_depend>roscpp</build_depend> -->
<!-- <exec_depend>roscpp</exec_depend> -->
<!-- <build_depend>message_generation</build_depend> -->
<!-- <build_export_depend>message_generation</build_export_depend> -->
<!-- <buildtool_depend>catkin</buildtool_depend> -->
<!-- <exec_depend>message_runtime</exec_depend> -->
<!-- <test_depend>gtest</test_depend> -->
<!-- <doc_depend>doxygen</doc_depend> -->
<export>
</export>
</package>
But when I do catkin_make
I get the following error
– Using these message generators: gencpp;geneus;genlisp;gennodejs;genpy
CMake Error at /home/user/catkin_ws/build/fetch_train/cmake/fetch_train-genmsg.cmake:3 (message):
Could not find messages which
‘/home/user/catkin_ws/src/fetch_train/srv/EePose.srv’ depends on. Did you
forget to specify generate_messages(DEPENDENCIES …)?
Cannot locate message [Pose]: unknown package [geometry_msgs] on search
path [{{'std_msgs': ['/opt/ros/kinetic/share/std_msgs/cmake/../msg']}}]
/opt/ros/kinetic/share/genmsg/cmake/genmsg-extras.cmake:307 (include)
fetch_train/CMakeLists.txt:73 (generate_messages)
-- Configuring incomplete, errors occurred!
See also "/home/user/catkin_ws/build/CMakeFiles/CMakeOutput.log".
See also "/home/user/catkin_ws/build/CMakeFiles/CMakeError.log".
Makefile:318: recipe for target 'cmake_check_build_system' failed
make: *** [cmake_check_build_system] Error 1
Invoking "make cmake_check_build_system" failed
user:~/catkin_ws$
