Hello this is Sangdon. I have a question why my codes are wrong for the services.quiz It says it is not turning as its suppose to turn.
Hi @sang23141, will check what’s going on. Thanks
We just released an upgrade of the correcting script that should be more robust to differences in code.Basically now if your robot turns right during three seconds , it should mark it as correct the last three points.
Hi @sang23141 We executed the gradebot with the new upgrade and your grade was fixed to 10/10 . Sorry for the inconvenience. If you find any other issue please don’t hesitate to tell us. We try to make the platform everyday better and better thanks to all you students feedbacks.
