Hello there,
Before the generative AI course becomes accessable only via the enterprise subscription, I thought I’d give it a try. While reading through chapter 3, doing the exercises and opening the links for further reading, I encounter two problems / errors.:
- the external link to the “Attention is all you need”-paper does not work.
- the collapsed code snippets are not rendered correctly. The train_model_improv.py in chapter 3 for example seems to be rendered as something latex-like.
Help would be much appreciated, because chapter 4 starts of with the generate_csv.py file that has the same rendering problem.
