Command Prompt is not working after entering “man ls” command, even after pressing key “q”
Hi @sanketjain544,
In general you can abort any process in the Terminal by pressing ctrl-c or sometimes ctrl-z
Hi @sanketjain544,
Thanks for letting us know and welcome to the Community!
I apologize for this error. It’s a known stubborn bug of the terminal and we are working on fixing it.
Please click on the reload simulation
button at the top right corner of the simulation window to reload the shells. Apologies for the inconvenience.
and even pressing the simulation reset button it is not working at all
user:/home/simulations/public_sim_ws/src/all/ros_basics_examples/linux_demo$ ./demo.sh
./demo.sh: line 4: 1501ARG1: command not found
./demo.sh: line 5: [: ==: unary operator expected
./demo.sh: line 15: [: ==: unary operator expected
./demo.sh: line 25: [: ==: unary operator expected
Hi @ramku31, welcome to the Community!
Apologies for the error! We will look into this. In the meantime:
- Please avoid using
man ls. - If the shell hangs again, please just change to a unit that uses a different simulation and then change back.
Hi @ramku31,
the problem has finally been “solved”.
If you now type the man command, you will just get the following message:
Please, see man reference in a new tab: https://manpages.ubuntu.com/
Thanks for reporting the problem.
