Comparison to Gazebo v11
Gazebo was replaced by Gazebo v11. Are the launch codes and related file structures different. If they are different where can I find the references to use v11?
Hi @ROxX ,
You need to be a little more specif when you refer to Gazebo.
There are two versions - Gazebo Classic and GazeboSim (previously known as Ignition).
Gazebo Classic has reached End of Life and will be ported to GazeboSim in the future.
Currently Gazebo Classic is version 11. Whereas GazeboSim is known by code names such as Fortress, Garden, Harmonic, etc.
So, please clarify for which version of the Gazebo Simulator you need the references and file structures.
