Hello @mccannm,
That specific message (the one in red) indicates that in Task 2, section b), the expected string result from the Service, which should contain something like: βThe drone has moved X metersβ, was not received. I will modify that feedback since I can see itβs very confusing.
Thanks,
Below is a section of my code for the problem I am confused on what incorrect
new_dist = 5
rospy.loginfo("The drone has moved "+str(new_dist)+ "meters.")
tran = servicemessage()
tran.dist= "The drone hass moved "+str(new_dist)+ " meters."
return tran
rospy.loginfo("Finished service ")
response = servicemessageResponse()
response.success = True
return response
