Within 2 -ROS 2 basics im getting a warning when creating package
This warning is just to let you know that by default no license has been declared. In the context of the course and files that reside on a VM changing it in the package.xml manually is up to you. Outside of the course, you would choose license based on circumstance. The license informs others of the terms and conditions to use the package/code should it be publicly available.
Okay, I was having trouble with the setup.py later on, and I thought this was the cause, thanks.
Hi @costell ,
Welcome to this Community!
One way to get rid if that “license” warning is to uncomment a single line in the CMakeLists.txt file.
set(ament_cmake_copyright_FOUND TRUE) # <--- uncomment this line
# see below code snippet to find the location of this line
if(BUILD_TESTING)
# uncomment the line when a copyright and license is not present in all source files
set(ament_cmake_copyright_FOUND TRUE) # <<<--- uncomment this line <<<-<<<---
# uncomment the line when this package is not in a git repo
endif()
I think this should solve your warning indication.
