I am learning unit2 of “machine learning of robotic”. In topic “2.5 Logistic Regression - Cost Function”, the code for logistic regression is like:
# Definition of class
class LogisticRegression:
def __init__(self, lr=0.0001, num_iter=100000):
self.lr = lr
self.num_iter = num_iter
self.logistic_loss = []
def __add_intercept(self, X):
intercept = np.ones((X.shape[0], 1))
return np.concatenate((intercept, X), axis=1)
def __sigmoid(self, z):
return 1 / (1 + np.exp(-z))
def __loss(self, h, y):
return (-y * np.log(h) - (1 - y) * np.log(1 - h)).mean()
def fit(self, X, y):
self.theta = np.zeros(X.shape[1])
for i in range(self.num_iter):
z = np.dot(X, self.theta)
h = self.__sigmoid(z)
gradient = np.dot(X.T, (h - y)) / y.size
self.theta -= self.lr * gradient
loss = self.__loss(h, y)
if(i % 1000 == 0):
self.logistic_loss.append(loss)
if(i % 5000 == 0):
print ("i:", i, "loss: ", loss)
def predict_prob(self, X):
#if self.fit_intercept:
# X = self.__add_intercept(X)
return self.__sigmoid(np.dot(X, self.theta))
def predict(self, X):
return self.predict_prob(X).round()
#creating a object to Logistic Regression
model = LogisticRegression(lr=0.1, num_iter=100000)
# Now we will learn our model
model.fit(X, y)
# print the eroor while training
plt.figure(figsize=(10, 8))
i = np.arange(0, len(model.logistic_loss),1)
plt.plot(i, model.logistic_loss)
plt.xlabel("Iteration", fontsize=16)
plt.ylabel("Error", fontsize=16)
plt.show()
# print logistic regression applied to data set
plt.scatter(X[y == 0][:, 0], X[y == 0][:, 1], label='0')
plt.scatter(X[y == 1][:, 0], X[y == 1][:, 1], label='1')
plt.legend()
x1_min, x1_max = X[:,0].min(), X[:,0].max(),
x2_min, x2_max = X[:,1].min(), X[:,1].max(),
xx1, xx2 = np.meshgrid(np.linspace(x1_min, x1_max), np.linspace(x2_min, x2_max))
grid = np.c_[xx1.ravel(), xx2.ravel()]
probs = model.predict_prob(grid).reshape(xx1.shape)
plt.xlabel("Deviation - x direction", fontsize=16)
plt.ylabel("Deviation - y direction", fontsize=16)
plt.contour(xx1, xx2, probs, [0.5], linewidths=1, colors='red')
plt.show()
and the contour shows like:
In the code above, the shape of probs is the same with xx1, which is of (50,50), which is determined by:
But I cannot unterstand what this contour actually is. Is it the contour of “probs”? Then why is the shape of an array with shape of (50,50) a red “line”? Or can anyone explain what is this line doing? How can I understand this “contour”?
