I am working on the course project and launching my path_planning launch file. It fails while configurating the controller server. This is my config file :
controller_server:
ros__parameters:
use_sim_time: True
controller_frequency: 10.0
min_y_velocity_threshold: 0.5
failure_tolerance: 0.3
progress_checker_plugin: "progress_checker"
goal_checker_plugins: ["general_goal_checker"]
controller_plugins: ["FollowPath"]
# Progress checker parameters
progress_checker:
required_movement_radius: 0.5
movement_time_allowance: 10.0
# Goal checker parameters
general_goal_checker:
stateful: True
xy_goal_tolerance: 0.25
yaw_goal_tolerance: 0.25
# DWB parameters
FollowPath:
min_vel_x: 0.0
min_vel_y: 0.0
max_vel_x: 0.26
max_vel_y: 0.0
max_vel_theta: 1.0
min_speed_xy: 0.0
max_speed_xy: 0.26
min_speed_theta: 0.0
acc_lim_x: 2.5
acc_lim_y: 0.0
acc_lim_theta: 3.2
decel_lim_x: -2.5
decel_lim_y: 0.0
decel_lim_theta: -3.2
vx_samples: 20
vy_samples: 5
vtheta_samples: 20
sim_time: 1.7
linear_granularity: 0.05
angular_granularity: 0.025
transform_tolerance: 0.2
trans_stopped_velocity: 0.25
stateful: True
BaseObstacle.scale: 0.02
PathAlign.scale: 32.0
GoalAlign.scale: 24.0
PathDist.scale: 32.0
GoalDist.scale: 24.0
RotateToGoal.scale: 32.0
local_costmap:
ros__parameters:
update_frequency: 5.0
publish_frequency: 2.0
global_frame: odom
robot_base_frame: base_link
use_sim_time: True
rolling_window: true
width: 1
height: 1
resolution: 0.05
robot_radius: 0.15
plugins: ["voxel_layer", "inflation_layer"]
inflation_layer:
plugin: "nav2_costmap_2d::InflationLayer"
cost_scaling_factor: 3.0
inflation_radius: 0.35
voxel_layer:
plugin: "nav2_costmap_2d::VoxelLayer"
enabled: True
publish_voxel_map: True
origin_z: 0.0
z_resolution: 0.05
z_voxels: 16
max_obstacle_height: 2.0
mark_threshold: 0
observation_sources: scan
scan:
topic: /scan
clearing: True
marking: True
data_type: "LaserScan"
raytrace_max_range: 3.0
raytrace_min_range: 0.0
obstacle_max_range: 2.5
obstacle_min_range
And this is my launch file :
import os
controller_yaml = os.path.join(get_package_share_directory('project_path_planning'), 'config', 'controller_config.yaml')
bt_navigator_yaml = os.path.join(get_package_share_directory('project_path_planning'), 'config', 'navigator_config.yaml')
planner_yaml = os.path.join(get_package_share_directory('project_path_planning'), 'config', 'planner_config.yaml')
recovery_yaml = os.path.join(get_package_share_directory('project_path_planning'), 'config', 'recovery_config.yaml')
return LaunchDescription([
Node(
package='nav2_controller',
executable='controller_server',
name='controller_server',
output='screen',
parameters=[controller_yaml]),
Node(
package='nav2_planner',
executable='planner_server',
name='planner_server',
output='screen',
parameters=[planner_yaml]),
Node(
package='nav2_recoveries',
executable='recoveries_server',
name='recoveries_server',
parameters=[recovery_yaml],
output='screen'),
Node(
package='nav2_bt_navigator',
executable='bt_navigator',
name='bt_navigator',
output='screen',
parameters=[bt_navigator_yaml]),
Node(
name='lifecycle_manager_pathplanner',
output='screen',
parameters=[{'autostart': True},
{'node_names': ['planner_server',
'bt_navigator']}])
And this is the terminal output:
[INFO] [launch]: All log files can be found below /home/user/.ros/log/2023-07-27-14-04-54-910380-2_xterm-7652
[WARNING] [launch_ros.actions.node]: Parameter file path is not a file: /home/user/ros2_ws/install/project_path_planning/share/project_path_planning/config/controller_config.yaml
[WARNING] [launch_ros.actions.node]: Parameter file path is not a file: /home/user/ros2_ws/install/project_path_planning/share/project_path_planning/config/planner_config.yaml
[WARNING] [launch_ros.actions.node]: Parameter file path is not a file: /home/user/ros2_ws/install/project_path_planning/share/project_path_planning/config/recovery_config.yaml
[WARNING] [launch_ros.actions.node]: Parameter file path is not a file: /home/user/ros2_ws/install/project_path_planning/share/project_path_planning/config/navigator_config.yaml
[INFO] [controller_server-1]: process started with pid [7673]
[INFO] [planner_server-2]: process started with pid [7675]
[INFO] [recoveries_server-3]: process started with pid [7677]
[INFO] [bt_navigator-4]: process started with pid [7679]
[INFO] [lifecycle_manager-5]: process started with pid [7681]
[planner_server-2] [INFO] [1690466697.494064696] [planner_server]:
[planner_server-2] planner_server lifecycle node launched.
[planner_server-2] Waiting on external lifecycle transitions to activate
[planner_server-2] See https://design.ros2.org/articles/node_lifecycle.html for more information.
[controller_server-1] [INFO] [1690466697.499648433] [controller_server]:
[controller_server-1] controller_server lifecycle node launched.
[controller_server-1] Waiting on external lifecycle transitions to activate
[controller_server-1] See https://design.ros2.org/articles/node_lifecycle.html for more information.
[planner_server-2] [INFO] [1690466697.508447382] [planner_server]: Creating
[recoveries_server-3] [INFO] [1690466697.588751122] [recoveries_server]:
[recoveries_server-3] recoveries_server lifecycle node launched.
[recoveries_server-3] Waiting on external lifecycle transitions to activate
[recoveries_server-3] See https://design.ros2.org/articles/node_lifecycle.html for more information.
[planner_server-2] [INFO] [1690466697.597093236] [global_costmap.global_costmap]:
[planner_server-2] global_costmap lifecycle node launched.
[planner_server-2] [INFO] [1690466697.599781334] [global_costmap.global_costmap]: Creating Costmap
[bt_navigator-4] [INFO] [1690466697.686782740] [bt_navigator]:
[bt_navigator-4] bt_navigator lifecycle node launched.
[bt_navigator-4] Waiting on external lifecycle transitions to activate
[bt_navigator-4] See https://design.ros2.org/articles/node_lifecycle.html for more information.
[bt_navigator-4] [INFO] [1690466697.686951477] [bt_navigator]: Creating
[controller_server-1] [INFO] [1690466697.707173197] [controller_server]: Creating controller server
[controller_server-1] [INFO] [1690466697.799209898] [local_costmap.local_costmap]:
[controller_server-1] local_costmap lifecycle node launched.
[controller_server-1] [INFO] [1690466697.802118475] [local_costmap.local_costmap]: Creating Costmap
[lifecycle_manager-5] [INFO] [1690466697.885652130] [lifecycle_manager_pathplanner]: Creating
[lifecycle_manager-5] [INFO] [1690466697.895596142] [lifecycle_manager_pathplanner]: Creating and initializing lifecycle service clients
[lifecycle_manager-5] [INFO] [1690466697.985044859] [lifecycle_manager_pathplanner]: Starting managed nodes bringup...
[lifecycle_manager-5] [INFO] [1690466697.985116246] [lifecycle_manager_pathplanner]: Configuring planner_server
[planner_server-2] [INFO] [1690466697.985484259] [planner_server]: Configuring
[planner_server-2] [INFO] [1690466697.985552821] [global_costmap.global_costmap]: Configuring
[planner_server-2] [INFO] [1690466697.990149944] [global_costmap.global_costmap]: Using plugin "static_layer"
[planner_server-2] [INFO] [1690466698.000978947] [global_costmap.global_costmap]: Subscribing to the map topic (/map) with transient local durability
[planner_server-2] [INFO] [1690466698.003789157] [global_costmap.global_costmap]: Initialized plugin "static_layer"
[planner_server-2] [INFO] [1690466698.003833674] [global_costmap.global_costmap]: Using plugin "obstacle_layer"
[planner_server-2] [INFO] [1690466698.006735550] [global_costmap.global_costmap]: Subscribed to Topics:
[planner_server-2] [INFO] [1690466698.006796598] [global_costmap.global_costmap]: Initialized plugin "obstacle_layer"
[planner_server-2] [INFO] [1690466698.006813060] [global_costmap.global_costmap]: Using plugin "inflation_layer"
[planner_server-2] [INFO] [1690466698.007205473] [global_costmap.global_costmap]: Initialized plugin "inflation_layer"
[planner_server-2] [INFO] [1690466698.088842695] [planner_server]: Created global planner plugin GridBased of type nav2_navfn_planner/NavfnPlanner
[planner_server-2] [INFO] [1690466698.088918203] [planner_server]: Configuring pluginGridBased of type NavfnPlanner
[planner_server-2] [INFO] [1690466698.094207033] [planner_server]: Planner Server hasGridBased planners available.
[lifecycle_manager-5] [INFO] [1690466698.107198022] [lifecycle_manager_pathplanner]: Configuring controller_server
[controller_server-1] [INFO] [1690466698.107508660] [controller_server]: Configuring controller interface
[controller_server-1] [INFO] [1690466698.107745653] [controller_server]: getting goalchecker plugins..
[controller_server-1] [INFO] [1690466698.108052169] [controller_server]: Controller frequency set to 20.0000Hz
[controller_server-1] [INFO] [1690466698.108098256] [local_costmap.local_costmap]: Configuring
[controller_server-1] [INFO] [1690466698.186212540] [local_costmap.local_costmap]: Using plugin "static_layer"
[controller_server-1] [INFO] [1690466698.198100343] [local_costmap.local_costmap]: Subscribing to the map topic (/map) with transient local durability
[controller_server-1] [INFO] [1690466698.199660278] [local_costmap.local_costmap]: Initialized plugin "static_layer"
[controller_server-1] [INFO] [1690466698.199706469] [local_costmap.local_costmap]: Using plugin "obstacle_layer"
[controller_server-1] [INFO] [1690466698.202487047] [local_costmap.local_costmap]: Subscribed to Topics:
[controller_server-1] [INFO] [1690466698.202579186] [local_costmap.local_costmap]: Initialized plugin "obstacle_layer"
[controller_server-1] [INFO] [1690466698.202609102] [local_costmap.local_costmap]: Using plugin "inflation_layer"
[controller_server-1] [INFO] [1690466698.205661169] [local_costmap.local_costmap]: Initialized plugin "inflation_layer"
[controller_server-1] [INFO] [1690466698.283084695] [controller_server]: Created progress_checker : progress_checker of type nav2_controller::SimpleProgressChecker
[controller_server-1] [INFO] [1690466698.293894884] [controller_server]: Created goalchecker : goal_checker of type nav2_controller::SimpleGoalChecker
[controller_server-1] [INFO] [1690466698.303042142] [controller_server]: Controller Server has goal_checker goal checkers available.
[controller_server-1] [INFO] [1690466698.310556066] [controller_server]: Created controller : FollowPath of type dwb_core::DWBLocalPlanner
[controller_server-1] [INFO] [1690466698.311189404] [controller_server]: Setting transform_tolerance to 0.100000
[controller_server-1] [ERROR] [1690466698.405826320] [controller_server]: Couldn't load critics! Caught exception: No critics defined for FollowPath
[controller_server-1] [ERROR] [1690466698.497434808] []: Caught exception in callbackfor transition 10
[controller_server-1] [ERROR] [1690466698.497478689] []: Original error: No critics defined for FollowPath
[controller_server-1] [WARN] [1690466698.497521291] []: Error occurred while doing error handling.
[controller_server-1] [FATAL] [1690466698.497535321] [controller_server]: Lifecycle node controller_server does not have error state implemented
[lifecycle_manager-5] [ERROR] [1690466698.498083229] [lifecycle_manager_pathplanner]:Failed to change state for node: controller_server
[lifecycle_manager-5] [ERROR] [1690466698.498130790] [lifecycle_manager_pathplanner]:Failed to bring up all requested nodes. Aborting bringup.
The error is related to the lack of follow_path critics.
