Hello @23f3000345 ,
Let me try to explain everything in a more intuitive way
Simple Convolution
So from the image you shared, the basic convolution is done like this:
kernel = [3, 1, 3]
input = [1, 0, 2, 3, 0, 1, 1]
output = [9, 11, 9, 12, 4]
Which is:
output[0] = 1*3 + 0*1 + 2*3
output[1] = 0*3 + 2*1 + 3*3
That’s standard convolution, where:
- Kernel is applied left-to-right
- We slide it over input
- We use padding (with 0s) so that we can apply it even at the edges
Now, the *"start at kernel[0]input[10]" kind of behavior feels strange because it’s not this “standard” form. That’s circular convolution, with a reversed kernel.
Now Let’s Decode This Formula:
index = (i + (width - k) - offset) % N
Let’s understand each piece step by step.
i: output index
You’re computing output[i].
k: position in kernel (e.g., k=0 is the first kernel element)
width - k: This flips the kernel
Think of it like we want to align the end of the kernel with the current position i.
If kernel = [a, b, c], then flipped it becomes [c, b, a].
offset: Where to center the kernel
This helps you decide whether kernel[1] aligns with input[i], or maybe kernel[0] or kernel[2] does.
If offset = width // 2, the kernel is centered.
If offset = 0, it’s causal (kernel is fully behind the current index).
% N: Wraps the input (makes it circular)
So What Does It All Mean?
Think of it like this:
“To compute output[i], flip the kernel, shift it back by offset, and apply it to the input values wrapping around the array.”
So if:
width = 3 (kernel has 3 elements)
offset = 1 → center the kernel at i
- Then:
index = (i + (3 - k) - 1) % N
= (i + 2 - k) % N
So for each k = 0, 1, 2, you’re grabbing:
input[i + 2 - 0] → for k=0 → input ahead of i
input[i + 2 - 1] → for k=1 → input at i+1
input[i + 2 - 2] → for k=2 → input at i
So this setup is applying the reversed kernel, centered at i.
Hope this helps clarify things a little bit!
