So I looked at the example solution for the action_server, with the 3 scripts and triple launch file and I fail to understand the purpose of this. My solution seems much simpler, shorter. What are the advantages of the example approach, what could be problems with mine?
My record_odom.action (kept the name from example):
#goal Empty
result definition
bool success
float64 time
#feedback
float64 distance
float64 time
my record_odom_action_server.py (I left out the imports here to make it shorter)
class RecordOdomClass(object): def __init__(self): self.maxtime = 60 self.maxdist = 2 self.rate = rospy.Rate(25) self._odom_reader_object = OdomTopicReader() self._as = actionlib.SimpleActionServer("record_odom_as", record_odomAction, self.goal_callback, False) self._as.start() self.ctrl_c = False self._result = record_odomResult() self._feedback = record_odomFeedback self._result.success = False rospy.on_shutdown(self.shutdownhook) rospy.loginfo('record_odom_as Server ready, waiting for calls') def goal_callback(self, goal): # this callback is called when the action server is called. start_time = time.time() start_pos = self._odom_reader_object.get_odomdata().pose.pose.position while not self.ctrl_c: pos = self._odom_reader_object.get_odomdata().pose.pose.position distance = sqrt(pow(start_pos.x-pos.x,2)+pow(start_pos.y-pos.y,2)+pow(start_pos.z-pos.z,2)) if distance > self.maxdist: self._result.success = True break if time.time() - start_time > self.maxtime: break self.rate.sleep() self._result.time = time.time() - start_time return self._result self._as.set_succeeded(self._result) def shutdownhook(self): # works better than the rospy.is_shutdown() self.ctrl_c = Trueif name == ‘main’:
rospy.init_node(‘record_odom_action_server_node’)
RecordOdomClass()
rospy.spin()
