Error found in Colcon Build of Cmake file. I do see any errors from the reference
Hi @ROxX ,
The error clearly states that you should include the following line in your package.xml file:
<member_of_group>rosidl_interface_packages</member_of_group>
Refer to the course instructions on how to create a custom interfaces to know where to add the above mentioned line.
Your package.xml file should include the above line as shown below:
Between <depend> and <test_depend> tags.
<?xml version="1.0"?>
<package format="3">
<name>services_quiz_srv</name>
<version>0.0.0</version>
<buildtool_depend>ament_cmake</buildtool_depend>
<depend>rclcpp</depend>
<depend>std_msgs</depend>
<depend>std_srvs</depend>
<build_depend>rosidl_default_generators</build_depend>
<exec_depend>rosidl_default_runtime</exec_depend>
<test_depend>ament_lint_auto</test_depend>
<test_depend>ament_lint_common</test_depend>
<export>
<build_type>ament_cmake</build_type>
</export>
</package>
This should solve your issue. let me know if this does not fix your issue.
