I am currently doing the exercise 6.3 which consist of calling a new service though a custom service message.
However, everytime I create a new custom service or message, it never works.
I gave up on the unit 4.2 “Prepare CMakeLists.txt and package.xml for custom Message compilation” because I was wasting too much time.
Even with the copy and paste answer, the launch file doesn’t work :
If you are talking abour my_custom_srv_msg_pkg , here are my files :
CMAKELISTS.txt :
project(my_custom_srv_msg_pkg)
## Here is where all the packages needed to COMPILE the messages of topics, services and actions go.
## It's only getting its paths, and not really importing them to be used in the compilation.
## It's only for further functions in CMakeLists.txt to be able to find those packages.
## In package.xml you have to state them as build
std_msgs
message_generation
## In this function will be all the action messages of this package ( in the action folder ) to be compiled.
## You can state that it gets all the actions inside the action directory: DIRECTORY action
## Or just the action messages stated explicitly: FILES my_custom_action.action
## In your case you only need to do one of two things, as you wish.
add_service_files(
FILES
MyCustomServiceMessage.srv
## Here is where the packages needed for the action messages compilation are imported.
generate_messages(
DEPENDENCIES
std_msgs
## State here all the packages that will be needed by someone that executes something from your package.
## All the packages stated here must be in the package.xml as exec_depend
catkin_package(
CATKIN_DEPENDS rospy
include_directories(
${catkin_INCLUDE_DIRS}
I wanted you to post the package that is using the custom message as a dependency.
I think the package is unit_4_services, for which I need the CMakeLists and package files.
By the way, your custom message package’s CMakeLists and package files are correct. Although, your package.xml needs some tag grouping for better readability. Put build_depend tags together, likewise for build_export_depend and exec_depend tags.
Sorry for the confusion, here is the CMakelists file of the package unit_4_services :
project(unit_4_services)
rospy
std_msgs
# catkin_python_setup()
## * In the file package.xml:
# add_message_files(
# FILES
# Message1.msg
# Message2.msg
# add_service_files(
# FILES
# Service1.srv
# Service2.srv
# add_action_files(
# FILES
# Action1.action
# Action2.action
# generate_messages(
# DEPENDENCIES
# std_msgs
# cfg/DynReconf1.cfg
# cfg/DynReconf2.cfg
catkin_package(
# INCLUDE_DIRS include
# LIBRARIES unit_4_services
# CATKIN_DEPENDS rospy std_msgs
# DEPENDS system_lib
## Build ##
# include
## Declare a C++ library
# add_library(${PROJECT_NAME}
# src/${PROJECT_NAME}/unit_4_services.cpp
## Declare a C++ executable
# add_executable(${PROJECT_NAME}_node src/unit_4_services_node.cpp)
# ${catkin_LIBRARIES}
## Install ##
# scripts/my_python_script
# PATTERN ".svn" EXCLUDE
# install(FILES
# # myfile1
# # myfile2
## Testing ##
# catkin_add_gtest(${PROJECT_NAME}-test test/test_unit_4_services.cpp)
# endif()
# catkin_add_nosetests(test)
package file (I haven’t edit this one) :
<?xml version="1.0"?>
<package format="2">
<name>unit_4_services</name>
<version>0.0.0</version>
<description>The unit_4_services package</description>
<!-- Example: -->
<!-- BSD, MIT, Boost Software License, GPLv2, GPLv3, LGPLv2.1, LGPLv3 -->
<license>TODO</license>
<!-- Example: -->
<!-- <url type="website">http://wiki.ros.org/unit_4_services</url> -->
<!-- Example: -->
<!-- Examples: -->
<!-- <depend>roscpp</depend> -->
<!-- Note that this is equivalent to the following: -->
<!-- <build_depend>roscpp</build_depend> -->
<!-- <exec_depend>roscpp</exec_depend> -->
<!-- <build_depend>message_generation</build_depend> -->
<!-- <build_export_depend>message_generation</build_export_depend> -->
<!-- <buildtool_depend>catkin</buildtool_depend> -->
<!-- <exec_depend>message_runtime</exec_depend> -->
<!-- <test_depend>gtest</test_depend> -->
<!-- <doc_depend>doxygen</doc_depend> -->
<export>
</export>
</package>
Lastly, you need to make sure you compile from scratch:
cd ~/catkin_ws
rm -rf ./build ./devel
# compile custom message package first
catkin_make --only-pkg-with-deps my_custom_srv_msg_pkg
# then compile all other packages
catkin_make && source devel/setup.bash
# run your executable here
roslaunch / rosrun ...
