As for these two courses, Web Development for Robotics is listed as Enterprise course - meaning, you need Enterprise learning license. This course is using ROS1 (not ROS2). Developing Web Interfaces for ROS - is a regular course - you can use your usual subscription. This course is based on ROS1 (not ROS2). But I believe you can apply the same concepts with ROS2, once you get the hang of it.
