Doubt in command Unit 3: Train your own TensorFlow
I’m following the Unit 3 and in Step 5 we call the train.py script with some flags:
  • dataset and val_dataset: are both new files
  • classes and num_classes: correpond to the new classes
But I don’t understand what’s the point of “weights” and “weights_num_classes” parameters. As far as I know, the “yolov3.tf” corresponds to another previous example, and the “num_coco_classes” is 80.
I don’t understand these two parameters. If you can give me some explaination I would be happy.
Thanks
Juan
We are using the previous example DeepLearning Model Yolo with 80 clases as base for us to afterwards retrain it for only One or two clases ( in thi scase mir_robot and objects ). So we need that data to start to be able to retrain the model.
Hi duckfrost,
Thank you for your answer.
Juan
