Hello @balajigunasekeran22 ,
Here you have an example code working:
#!/usr/bin/env python
from __future__ import print_function
from select import select
import sys
from geometry_msgs.msg import TwistStamped
import threading
import roslib
roslib.load_manifest('teleop_twist_keyboard')
if sys.platform == 'win32':
import msvcrt
else:
import termios
import tty
TwistMsg = Twist
msg = """
Reading from the keyboard and Publishing to Twist!
Moving around:
u i o
j k l
m , .
For Holonomic mode (strafing), hold down the shift key:
U I O
J K L
M < >
t : up (+z)
b : down (-z)
anything else : stop
q/z : increase/decrease max speeds by 10%
w/x : increase/decrease only linear speed by 10%
e/c : increase/decrease only angular speed by 10%
CTRL-C to quit
moveBindings = {
'i': (1, 0, 0, 0),
'o': (1, 0, 0, -1),
'j': (0, 0, 0, 1),
'l': (0, 0, 0, -1),
'u': (1, 0, 0, 1),
',': (-1, 0, 0, 0),
'.': (-1, 0, 0, 1),
'm': (-1, 0, 0, -1),
'O': (1, -1, 0, 0),
'I': (1, 0, 0, 0),
'J': (0, 1, 0, 0),
'L': (0, -1, 0, 0),
'U': (1, 1, 0, 0),
'<': (-1, 0, 0, 0),
'>': (-1, -1, 0, 0),
'M': (-1, 1, 0, 0),
't': (0, 0, 1, 0),
'b': (0, 0, -1, 0),
speedBindings = {
'q': (1.1, 1.1),
'z': (.9, .9),
'w': (1.1, 1),
'x': (.9, 1),
'e': (1, 1.1),
'c': (1, .9),
class PublishThread(threading.Thread):
def __init__(self, rate):
super(PublishThread, self).__init__()
self.publisher = rospy.Publisher('cmd_vel', TwistMsg, queue_size=1)
self.x = 0.0
self.y = 0.0
self.z = 0.0
self.th = 0.0
self.speed = 0.0
self.turn = 0.0
self.condition = threading.Condition()
self.done = False
# Set timeout to None if rate is 0 (causes new_message to wait forever
# for new data to publish)
if rate != 0.0:
self.timeout = 1.0 / rate
else:
self.timeout = None
self.start()
def wait_for_subscribers(self):
i = 0
while not rospy.is_shutdown() and self.publisher.get_num_connections() == 0:
if i == 4:
print("Waiting for subscriber to connect to {}".format(
self.publisher.name))
rospy.sleep(0.5)
i += 1
i = i % 5
if rospy.is_shutdown():
raise Exception(
"Got shutdown request before subscribers connected")
def update(self, x, y, z, th, speed, turn):
self.condition.acquire()
self.x = x
self.y = y
self.z = z
self.th = th
self.speed = speed
self.turn = turn
# Notify publish thread that we have a new message.
self.condition.notify()
self.condition.release()
def stop(self):
self.done = True
self.update(0, 0, 0, 0, 0, 0)
self.join()
def run(self):
twist_msg = TwistMsg()
if stamped:
twist = twist_msg.twist
twist_msg.header.stamp = rospy.Time.now()
twist_msg.header.frame_id = twist_frame
else:
twist = twist_msg
while not self.done:
if stamped:
# Wait for a new message or timeout.
self.condition.wait(self.timeout)
# Copy state into twist message.
twist.linear.x = self.x * self.speed
twist.linear.y = self.y * self.speed
twist.linear.z = self.z * self.speed
twist.angular.x = 0
twist.angular.y = 0
twist.angular.z = self.th * self.turn
# Publish.
self.publisher.publish(twist_msg)
# Publish stop message when thread exits.
twist.linear.x = 0
twist.linear.y = 0
twist.linear.z = 0
twist.angular.x = 0
twist.angular.y = 0
twist.angular.z = 0
def getKey(settings, timeout):
# getwch() returns a string on Windows
key = msvcrt.getwch()
else:
tty.setraw(sys.stdin.fileno())
# sys.stdin.read() returns a string on Linux
rlist, _, _ = select([sys.stdin], [], [], timeout)
if rlist:
key = sys.stdin.read(1)
else:
key = ''
termios.tcsetattr(sys.stdin, termios.TCSADRAIN, settings)
return key
def saveTerminalSettings():
return None
return termios.tcgetattr(sys.stdin)
def restoreTerminalSettings(old_settings):
return
termios.tcsetattr(sys.stdin, termios.TCSADRAIN, old_settings)
def vels(speed, turn):
return "currently:\tspeed %s\tturn %s " % (speed, turn)
if __name__ == "__main__":
settings = saveTerminalSettings()
rospy.init_node('teleop_twist_keyboard')
pub = rospy.Publisher('cmd_vel', Twist, queue_size=1)
pub2 = rospy.Publisher('drone/takeoff', Empty, queue_size=1)
pub3 = rospy.Publisher('drone/land', Empty, queue_size=1)
empty_msg = Empty()
speed = rospy.get_param("~speed", 0.5)
turn = rospy.get_param("~turn", 1.0)
speed_limit = rospy.get_param("~speed_limit", 1000)
turn_limit = rospy.get_param("~turn_limit", 1000)
repeat = rospy.get_param("~repeat_rate", 0.0)
key_timeout = rospy.get_param("~key_timeout", 0.5)
stamped = rospy.get_param("~stamped", False)
twist_frame = rospy.get_param("~frame_id", '')
if stamped:
TwistMsg = TwistStamped
pub_thread = PublishThread(repeat)
x = 0
y = 0
z = 0
th = 0
status = 0
try:
pub_thread.wait_for_subscribers()
pub_thread.update(x, y, z, th, speed, turn)
print(msg)
print(vels(speed, turn))
while(1):
key = getKey(settings, key_timeout)
if key in moveBindings.keys():
x = moveBindings[key][0]
y = moveBindings[key][1]
z = moveBindings[key][2]
th = moveBindings[key][3]
elif key in speedBindings.keys():
speed = min(speed_limit, speed * speedBindings[key][0])
turn = min(turn_limit, turn * speedBindings[key][1])
if speed == speed_limit:
print("Linear speed limit reached!")
if turn == turn_limit:
print("Angular speed limit reached!")
if (status == 14):
print(msg)
status = (status + 1) % 15
elif key == '1':
pub2.publish(empty_msg)
elif key == '2':
pub3.publish(empty_msg)
else:
# Skip updating cmd_vel if key timeout and robot already
# stopped.
if key == '' and x == 0 and y == 0 and z == 0 and th == 0:
continue
x = 0
y = 0
z = 0
th = 0
if (key == '\x03'):
break
except Exception as e:
print(e)
finally:
pub_thread.stop()
restoreTerminalSettings(settings)
