On Part2 - Build a Robot, under “Spawn using Ignition Spawn Service” we do
export GZ_SIM_RESOURCE_PATH=/home/user/ros2_ws/src/robot_description/urdf:/home/user/ros2_ws/src
Why is it that under “Spawn using ROS2 Launch File” the launch file sets the variable “IGN_GAZEBO_RESOURCE_PATH” instead of “GZ_SIM_RESOURCE_PATH”? More importantly, why does it work?
Thank you!
Edit: Even on Part 3, some examples also use ign.messages for the message types, but these commands fail…
