i keep getting that error
Invoking “cmake” failed
i tried to delete devel and build and use catkin_make but no change
it says that it cannot find “iri_warm_reproduce_trajectory” package also but i am sure i did every thing write.
the full messag is
import os
catkin_make
#### Running command: "cmake /home/user/catkin_ws/src -DCATKIN_DEVEL_PREFIX=/home/user/catkin_ws/devel -DCMAKE_INSTALL_PREFIX=/home/user/catkin_ws/install -G Unix Makefiles" in "/home/user/catkin_ws/build"
-- Using CATKIN_DEVEL_PREFIX: /home/user/catkin_ws/devel
-- Using CMAKE_PREFIX_PATH: /home/user/catkin_ws/devel;/home/simulations/public_sim_ws/devel;/opt/ros/noetic
-- This workspace overlays: /home/user/catkin_ws/devel;/home/simulations/public_sim_ws/devel;/opt/ros/noetic
-- Found PythonInterp: /usr/bin/python3 (found suitable version "3.8.5", minimum required is "3")
-- Using PYTHON_EXECUTABLE: /usr/bin/python3
-- Using Debian Python package layout
-- Using empy: /usr/lib/python3/dist-packages/em.py
-- Using CATKIN_ENABLE_TESTING: ON
-- Call enable_testing()
-- Using CATKIN_TEST_RESULTS_DIR: /home/user/catkin_ws/build/test_results
-- Forcing gtest/gmock from source, though one was otherwise available.
-- Found gtest sources under '/usr/src/googletest': gtests will be built
-- Found gmock sources under '/usr/src/googletest': gmock will be built
-- Found PythonInterp: /usr/bin/python3 (found version "3.8.5")
-- Using Python nosetests: /usr/bin/nosetests3
-- catkin 0.8.9
-- BUILD_SHARED_LIBS is on
-- ~~ traversing 4 packages in topological order:
-- ~~ - my_example
-- ~~ - my_service_client_example_pkg
-- ~~ - my_service_server_example_pkg
-- ~~ - unit_5_services
-- +++ processing catkin package: 'my_example'
-- ==> add_subdirectory(my_example)
-- Using these message generators: gencpp;geneus;genlisp;gennodejs;genpy
-- my_example: 1 messages, 0 services
-- +++ processing catkin package: 'my_service_client_example_pkg'
-- ==> add_subdirectory(my_service_client_example_pkg)
-- +++ processing catkin package: 'my_service_server_example_pkg'
-- ==> add_subdirectory(my_service_server_example_pkg)
-- +++ processing catkin package: 'unit_5_services'
-- ==> add_subdirectory(unit_5_services)
-- Could NOT find iri_warm_reproduce_trajectory (missing: iri_warm_reproduce_trajectory_DIR)
-- Could not find the required component 'iri_warm_reproduce_trajectory'. The following CMake error indicates that you either need to install the package with the same name or change your environment so that it can be found.
CMake Error at /opt/ros/noetic/share/catkin/cmake/catkinConfig.cmake:83 (find_package):
Could not find a package configuration file provided by
"iri_warm_reproduce_trajectory" with any of the following names:
iri_warm_reproduce_trajectoryConfig.cmake
iri_warm_reproduce_trajectory-config.cmake
Add the installation prefix of "iri_warm_reproduce_trajectory" to
CMAKE_PREFIX_PATH or set "iri_warm_reproduce_trajectory_DIR" to a directory
containing one of the above files. If "iri_warm_reproduce_trajectory"
provides a separate development package or SDK, be sure it has been
installed.
unit_5_services/CMakeLists.txt:10 (find_package)
-- Configuring incomplete, errors occurred!
See also "/home/user/catkin_ws/build/CMakeFiles/CMakeOutput.log".
See also "/home/user/catkin_ws/build/CMakeFiles/CMakeError.log".
Invoking "cmake" failed
my python file
import os
from iri_wam_reproduce_trajectory.srv import ExecTraj , ExecTrajRequest
import rospkg
rospack = rospkg.RosPack()
# This rospack.get_path() works in the same way as $(find name_of_package) in the launch files.
traj = rospack.get_path('iri_wam_reproduce_trajectory') + "/config/get_food.txt"
rospy.init_node("my_node")
rospy.wait_for_service("/execute_trajectory")
execute_traj_service = rospy.ServiceProxy("/execute_trajectory" ,ExecTraj )
execute_tarj_object = ExecTrajRequest()
execute_tarj_object.file = traj
result = execute_traj_service(execute_tarj_object)
print(result)
my launch
import os
<launch>
<include file = "$(find iri_wam_reproduce_trajectory)/launch/start_service.launch"/>
<node pkg = 'unit_5_services' type = 'my.py' name = 'my_node' output = 'screen' />
</launch>
