Everything should be fine. the service package that I made is as exactly as was told. What is the reason a failure to call another service package ? That’s the first time I see this error message. Thanks in advance
The error message is :
[ERROR] [1672315485.215086983]: Failed to call service /trajectory_by_name
[service_client-3] process has died [pid 1198, exit code 1, cmd /home/user/catkin_ws/devel/lib/service_client_pkg/simple_service_client __name:=service_client __log:=/home/user/.ros/log/d335e8e0-8770-11ed-a832-0242ac1a0007/service_client-3.log].
log file: /home/user/.ros/log/d335e8e0-8770-11ed-a832-0242ac1a0007/service_client-3*.log
Actually the service executes just fine for 5 seconds and waits for its call and then this error shows up.
Why would a service client process die ?
I am afraid I have changed by mistake the launch file of the trajectory_by_name service which is supposed to be called and not changed
That maybe really the case, because later when I typed in the first shell :
roslaunch trajectory_by_name start_service.launch
and the service was launched fined waiting for it’s call , in the second shell I typed :
rosservice call /trajectory_by_name “traj_name: ‘’”
I got in the second shell the error :
ERROR: service [/trajectory_by_name] responded with an error: b"service cannot process request: service [/execute_trajectory] responded with an error: b’'"
Hi @mouidsakka01 ,
I believe the solutions are available for those exercises [from what I remember when I did the course].
You can look them up if you really get stuck at some exercise.
Hi @mouidsakka01 ,
You are getting this error because you did not fill out the command for traj_name. It is blank by default, you need to fill it with the name of the trajectory you want!
Regards.
Thank you for that information! that was something new for me. But the thing is : the service doesn’t wait for the call . The solution published misses that . It misses in the source code the line ;
ros::service::waitForService(“/trajectory_by_name”); // wait for service to be running
I hope you add that to the solution ! I just added it to my code and it works fine!
