Hi thanks for the help thus far. I am encountering this error during unit 3.
Here is my CMakeLists file:
# scrubbed
I have correctly executed the catkin_make and source devel/setup.bash and it returns no errors. Also I have tried removing the build and devel folders
I get the error mentioned in the title after I try the command:
roslaunch topic_pub publish.launch
Please help. Thanks
Hi @bitcloude ,
You have not followed the tutorial properly.
- You have to make your C++ files as executable by doing chmod +x file_name.cpp
2. You must add the three build lines on your project CMakeLists.txt file as stated in the tutorial.
My advise: Just follow the tutorial again closely. Pay attention and make no mistake. Check if you have done all the steps. Then recompile.
If you still cannot figure out, then I / We will help you.
Hi @bitcloude ,
I just rechecked your CmakeLists. You have already added the three build lines.
So don’t do that again. Just do step 1.
Thanks Girish I will try that.
Hi @hanin.grisha2000,
I have provided execution permissions to my .cpp file and still get the same message.
Hi @bitcloude ,
Could you re-post your program code, CMakeLists.txt and package.xml contents as a code block?
This is a sample code block.
You can use the </> option when you write a post.
if (you.use_this){
we_can.help_you();
This error simply means that your C++ executable has not been created yet, or you have not sourced the workspace after compiling.
Please try recompiling/sourcing (see the commands below), and if that does not work, carefully go over editing CMakeLists.txt and package.xml so that your package is compiled properly.
cd ~/catkin_ws
rm -rf build/ devel/
catkin_make
typ#include <ros/ros.h>
#include <std_msgs/Int32.h>
int main(int argc, char** argv) {
ros::init(argc, argv, "topic_publisher");
ros::NodeHandle nh;
ros::Publisher pub = nh.advertise<std_msgs::Int32>("counter", 1000);
ros::Rate loop_rate(2);
std_msgs::Int32 count;
count.data = 0;
while (ros::ok())
pub.publish(count);
ros::spinOnce();
loop_rate.sleep();
++count.data;
return 0;
project(topic_pub)
roscpp
std_msgs
# catkin_python_setup()
## * In the file package.xml:
# add_message_files(
# FILES
# Message1.msg
# Message2.msg
# add_service_files(
# FILES
# Service1.srv
# Service2.srv
# add_action_files(
# FILES
# Action1.action
# Action2.action
# generate_messages(
# DEPENDENCIES
# std_msgs
# cfg/DynReconf1.cfg
# cfg/DynReconf2.cfg
catkin_package(
# INCLUDE_DIRS include
# LIBRARIES topic_publisher_pkg
# CATKIN_DEPENDS roscpp std_msgs
# DEPENDS system_lib
## Build ##
include_directories(
# include
${catkin_INCLUDE_DIRS}
## Declare a C++ library
# add_library(${PROJECT_NAME}
# src/${PROJECT_NAME}/topic_publisher_pkg.cpp
## Declare a C++ executable
# add_executable(${PROJECT_NAME}_node src/topic_publisher_pkg_node.cpp)
# ${catkin_LIBRARIES}
add_executable(simple_topic_publisher src/simple_topic_publisher.cpp)
add_dependencies(simple_topic_publisher ${simple_topic_publisher_EXPORTED_TARGETS} ${catkin_EXPORTED_TARGETS})
target_link_libraries(simple_topic_publisher
${catkin_LIBRARIES}
## Install ##
# scripts/my_python_script
# PATTERN ".svn" EXCLUDE
# install(FILES
# # myfile1
# # myfile2
## Testing ##
# catkin_add_gtest(${PROJECT_NAME}-test test/test_topic_publisher_pkg.cpp)
# endif()
# catkin_add_nosetests(test)
@hanin.grisha2000
<?xml version="1.0"?>
<package format="2">
<name>topic_pub</name>
<version>0.0.0</version>
<description>The topic_publisher_pkg package</description>
<!-- Example: -->
<!-- BSD, MIT, Boost Software License, GPLv2, GPLv3, LGPLv2.1, LGPLv3 -->
<license>TODO</license>
<!-- Example: -->
<!-- <url type="website">http://wiki.ros.org/topic_publisher_pkg</url> -->
<!-- Example: -->
<!-- Examples: -->
<!-- <depend>roscpp</depend> -->
<!-- Note that this is equivalent to the following: -->
<!-- <build_depend>roscpp</build_depend> -->
<!-- <exec_depend>roscpp</exec_depend> -->
<!-- <build_depend>message_generation</build_depend> -->
<!-- <build_export_depend>message_generation</build_export_depend> -->
<!-- <buildtool_depend>catkin</buildtool_depend> -->
<!-- <exec_depend>message_runtime</exec_depend> -->
<!-- <test_depend>gtest</test_depend> -->
<!-- <doc_depend>doxygen</doc_depend> -->
<build_export_depend>roscpp</build_export_depend>
<export>
</export>
</package>
<launch>
<node name = "topic_publisher" type=" topic_publisher " pkg="topic_pub" output="screen">
</node>
</launch>
@bitcloude
- On your main program I think there is a typo error on the very first line
typ#include <ros/ros.h>. Make it read #include <ros/ros.h>
- Your CMakeLists.txt file is correct.
- Your package.xml file is also correct.
So make sure when you compile you do the following:
cd catkin_ws
catkin_make --only-pkg-with-deps <your_package_name>
Then try doing rosrun command or roslaunch command to test your code.
Let me know if it worked!
@bitcloude
Your launch file has another typo error.
type=“topic_publisher” without spaces
<launch>
<node name="topic_publisher" type="topic_publisher" pkg="topic_pub" output="screen">
</node>
</launch>
@bitcloude
Your program should definitely work now!
Let me know if it does not!
@bayodesegun I have created the executable. I did source the workspace after compiling. The instructions for editing the package.xml file can be found where exactly? I did not see them in unit 2 or 3. I did also remove my build and devel packages
the “typ#include” comes from me pasting the code in the comment box. I forgot to copy the entire initial message and delete it all…“type or paste code here”
My source code doesn’t contain that error
I will try the remain points and let you know shortly
rosrun works just fine. The roslaunch command still does not
Interesting!
rosrun works but roslaunch does not. That is weird.
Do you get any errors when you do
roslaunch topic_pub <your_launch_file_name>.launch?
ERROR: cannot launch node of type [topic_pub/ topic_publisher ]: Cannot locate node of type [ topic_publisher ] in package [topic_pub]. Make sure file exists in package path and permission is set to executable (chmod +x)
