I am facing this error in Unit 3, and I have tried to do several things to solve the error
first:
CMakeList:
add_executable(simple_topic_publisher src/simple_topic_publisher.cpp)
add_dependencies(simple_topic_publisher ${simple_topic_publisher_EXPORTED_TARGETS} ${catkin_EXPORTED_TARGETS})
target_link_libraries(simple_topic_publisher
${catkin_LIBRARIES}
include_directories(
# include
${catkin_INCLUDE_DIRS}
Launch File
<launch>
<node pkg="topic_publisher_pkg " type="simple_topic_publisher" name="topic_publisher" output="screen">
</node>
</launch>
Tried Solutions
- I made sure all the names were exactly the same by copying file names
- When doing catkin make there were no errors
- I tried to remove build and devel
run from catkin_ws directory
rm -rf build/ devel/
cakin_make
source devel/setup.bash
4) I tried writing manually the cmake list which I did not fully understand why, but was mentioned in solutions
5) Finally I ran the cpp file via rosrun and it ran, but I know this is not a good solution
Not sure what to do
user:~/catkin_ws$ roslaunch topic_publisher_pkg topic_publisher_pkg_launch_file.launch
… logging to /home/user/.ros/log/a759fb10-ac16-11ed-b95e-0242c0a82006/roslaunch-3_xterm-11187.log
Press Ctrl-C to interrupt
started roslaunch server http://3_xterm:42215/
SUMMARY
PARAMETERS
- /rosdistro: noetic
- /rosversion: 1.15.9
NODES
nh (topic_publisher_pkg /simple_topic_publisher)
ROS_MASTER_URI=http://3_simulation:11311
ERROR: cannot launch node of type [topic_publisher_pkg /simple_topic_publisher]: topic_publisher_pkg
ROS path [0]=/opt/ros/noetic/share/ros
ROS path [1]=/home/user/catkin_ws/src
ROS path [2]=/home/simulations/public_sim_ws/src
ROS path [3]=/opt/ros/noetic/share
No processes to monitor
