I’ve just started Unit 5 of the ROS2 Basics in 5 Days course for Python. The course has worked well up until this point. However, now each time I try to execute a ros2 command in the shell I receive the following message:
[ERROR] [1638221201.517377591] [rcl]: Error getting RMW implementation identifier / RMW implementation not installed (expected identifier of 'rmw_cyclonedds_cpp'), with error message 'failed to find shared library of rmw implementation. Searched rmw_cyclonedds_cpp, at /tmp/binarydeb/ros-foxy-rmw-implementation-1.0.1/src/functions.cpp:54', exiting with 1., at /tmp/binarydeb/ros-foxy-rcl-1.1.9/src/rcl/rmw_implementation_identifier_check.c:139
I’ve confirmed that I’ve sourced the .bashrc_ros2 file at the beginning of the unit. Any help would be appreciated.
Echoing the RMW_IMPLEMENTATION variable returns “rmw_cyclonedds_cpp”.
