I’m facing this issue, when trying to use a Custom Message in python, could anyone please shed any light as to the problem?:
user:~/catkin_ws/src$ rosrun msg_example msg_test.py
File "/home/user/catkin_ws/src/msg_example/scripts/msg_test.py", line 4, in <module>
from msg_example.msg import Age
ImportError: No module named msg_example.msg
Python Script:
print("Hello World")
Steps Taken:
- Create Custom Message
- Edited package.xml
- Edited CMakeLists.txt
- “catkin_make” in workspace
- “source devel/setup.bash” in terminal.
- “rosmsg show msg_example/Age” correctly prints.
File Structure:
Age.msg Contents:
int32 years
int32 months
int32 days
CMakeLists:
project(msg_example)
message_generation
geometry_msgs
nav_msgs
rospy
sensor_msgs
std_msgs
# catkin_python_setup()
## * In the file package.xml:
add_message_files(FILES
Age.msg
# add_service_files(
# FILES
# Service1.srv
# Service2.srv
# add_action_files(
# FILES
# Action1.action
# Action2.action
geometry_msgs
nav_msgs
sensor_msgs
std_msgs
# cfg/DynReconf1.cfg
# cfg/DynReconf2.cfg
catkin_package(
# INCLUDE_DIRS include
# LIBRARIES msg_example
CATKIN_DEPENDS message_runtime geometry_msgs nav_msgs rospy sensor_msgs std_msgs
# DEPENDS system_lib
## Build ##
include_directories(
# include
${catkin_INCLUDE_DIRS}
## Declare a C++ library
# add_library(${PROJECT_NAME}
# src/${PROJECT_NAME}/msg_example.cpp
## Declare a C++ executable
# add_executable(${PROJECT_NAME}_node src/msg_example_node.cpp)
# ${catkin_LIBRARIES}
## Install ##
# scripts/my_python_script
# PATTERN ".svn" EXCLUDE
# install(FILES
# # myfile1
# # myfile2
## Testing ##
# catkin_add_gtest(${PROJECT_NAME}-test test/test_msg_example.cpp)
# endif()
# catkin_add_nosetests(test)
package.xml Contents:
<?xml version="1.0"?>
<package format="2">
<name>msg_example</name>
<version>0.0.0</version>
<description>The msg_example package</description>
<!-- Example: -->
<!-- BSD, MIT, Boost Software License, GPLv2, GPLv3, LGPLv2.1, LGPLv3 -->
<license>TODO</license>
<!-- Example: -->
<!-- <url type="website">http://wiki.ros.org/msg_example</url> -->
<!-- Example: -->
<!-- Examples: -->
<!-- <depend>roscpp</depend> -->
<!-- Note that this is equivalent to the following: -->
<!-- <build_depend>roscpp</build_depend> -->
<!-- <exec_depend>roscpp</exec_depend> -->
<!-- <build_depend>message_generation</build_depend> -->
<!-- <build_export_depend>message_generation</build_export_depend> -->
<!-- <buildtool_depend>catkin</buildtool_depend> -->
<!-- <exec_depend>message_runtime</exec_depend> -->
<!-- <test_depend>gtest</test_depend> -->
<!-- <doc_depend>doxygen</doc_depend> -->
<build_depend>geometry_msgs</build_depend>
<build_depend>nav_msgs</build_depend>
<build_depend>sensor_msgs</build_depend>
<build_export_depend>geometry_msgs</build_export_depend>
<build_export_depend>nav_msgs</build_export_depend>
<build_export_depend>sensor_msgs</build_export_depend>
<exec_depend>geometry_msgs</exec_depend>
<exec_depend>nav_msgs</exec_depend>
<exec_depend>sensor_msgs</exec_depend>
<export>
</export>
</package>
